Previous in Forum: oil bearing and grease bearing   Next in Forum: Vertical tank design
centrifugal pump
08/11/2008 5:17 PM
can i used centrifugal pump for slurry i.e. soap
thoughts becomes things.
Re: centrifugal pump
08/11/2008 6:27 PM
careful on the cavitation. suds would be everywhere
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
08/12/2008 1:55 AM
Hello
Please advice about the pressure, flow, temperature, available NPSH. Are missing to many information.
Thanks
Look over to the next challenge
08/12/2008 3:30 AM
Centrifugal pumps are high-shear, and possibly not recommended for this application.
If possible, select a low-shear pump from among the following possibilities:
  • gear pump
  • lobe pump
  • peristaltic pump
08/12/2008 6:05 AM
what is low and high shear
what will affect this shear factor
because where we are using the centrifugal pumps lines are not leaking because vibration is less
but where we are using lobe pumps line are leaking, we observed lines are vibrating
is it because of flow type
08/16/2008 2:01 PM
It sounds like you are already using centrifugal pumps.
Not knowing the scope of your pumping application limits your answers.
Lobed pumps do not give the near constant outlet pressure of a centrifugal pump.
You may be able to install a surge tank and / or a pressure control valve on the outlet of your pump to stop the vibration.
There may be no stupid questions - Some are just poorly contrived !
philroth (1); phoenix911 (1); PWSlack (1); sandeep lokhande (1); user-deleted-1104 (1)
