Previous in Forum: microcontroller   Next in Forum: IC chip also 3D stereo!!!
REQUEST FOR PROJECT TOPIC
08/12/2008 6:07 AM
pls can you help me with any project topic that deals with control engineering or elctrical / electtronics engineering?
thanks in anticipation of your quick reply.
Re: REQUEST FOR PROJECT TOPIC
08/12/2008 6:27 AM
This question is best directed locally to the tutor of the study course being undertaken.
Good Answers: 230
08/12/2008 6:39 AM
Hello idongjohnny
Is this a Class or Homework Question? Those are against the Rules.
If you are in a learning situation, as a student, apprentice, University, the thing you are going to need most in your life, is to learn the basic principle:
You should learn how to learn.
That means you do much of your own thinking, be able to form questions and do the basic research to locate the correct answers to those questions.
In doing that, you will remember most of what you find.
Understanding of every subject/Topic is difficult at first, but as you persist, then it becomes easier, because in your mind you have an organizational tree to attach the new facts.
So...the short answer to your Question is yes, I have tried to help you in your quest, and trust you will do the basic research to develop and find your own Project Topic.
If at this stage, you are unable to research and choose your own Topic, that would prove to me that rather than do that work yourself, you want someone else to do it for you.
As I said earlier, if you do the work yourself, you will have pride in your achievements, and will remember that research and facts, perhaps learning other new things in that process.
Unlike when I was much younger, you have the World's largest Library at your keyboard (we didn't have keyboards either) = The Internet, so use Search Engines to locate interesting subjects, make your selection and learn.
As you progress, you may then be able to assist others, which is truly rewarding.
I look forward to hearing from you, as you carefully choose your Topic, and advise of your progress.
Reply here, with
Kind Regards....
09/01/2008 1:13 PM
wow, thanks . that was great. but i did not mean to shift my responsibility. i just wanted to here from others. once more thanks. Ciao.
Register to Reply 3 comments
idongjohnny (1); PWSlack (1); Sparkstation (1)
