Previous in Forum: Microfaraday Capacitors: Fan Windings and Speeds   Next in Forum: Blinking Barricade Light
11 comments
Calculating Diesel Consumption in DG While Running in Full-Load
08/16/2008 3:51 AM
Dear sir,
pls send detailed reply for the title as soon as possible
with regards,
P. Prakash
Pathfinder Tags: Diesel calculation
Good Answers: 230
Re: How to calculate Diesel Consumption in DG while running in Full load
08/16/2008 5:42 AM
Hello prakash_venue@madhuri.com
Use a fuel meter, which monitors both instantaneous fuel usage, and total fuel usage per definite time increments.
I don't send emails to email addresses listed on public forms, is a public access forum.
You should not l;ist your email address on public forums, advises you should not list your email address, because of webcrawler robots, who harvest email addresses, and sell your email address, so you end up with much
Kind Regards....
08/16/2008 7:29 AM
i am using about mathematical calculation
those calculation should be related with Power, speed of the DG and other datas
pls give mathematical calculations to derive the values
with regards,
prakash
08/16/2008 1:07 PM
Your answer can not be answered with the supplied information. efficiency and fuel flow rates vary with manufacturer, use, and with individual generators.
To estimate your fuel usage, empty the tank, then fill with a measured amount of fuel. Time how long it takes for the generator to run out of fuel with whatever load you want on it. Take the amount of fuel and divide by the time and you should be able to get gal/hr or liters/hr.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
Good Answers: 247
08/17/2008 12:27 AM
In very general terms, a diesel will burn about 250ml/kW/hr, but that figure varies with the engine model, load and speed. To get an accurate figure at a particular load, you need to have the manufacturer's figures.
Good Answers: 19
08/18/2008 12:39 PM
In general terms, fuel burn KW will be around 2.5 to 3.3 KW per KW generated.
In more specific terms, consult the engine manufacturer's BSFC (Brake Specific Fuel Consumption) chart for the BSFC at various RPMs, and use this number to determine fuel burn at full KW output. BSFC varies from engine to engine, and varies by RPM.
The numbers can be converted to whatever usits of consumption you prefer.
Good Answers: 247
08/18/2008 1:43 PM
BSFC varies from engine to engine, and varies by RPM...
and load, with BSFC generally being lowest at the engine's torque peak load and rpm.
Incidentally, the 250ml/kW/hr figure I quoted is a typical BSFC for a small diesel, with the kW representing the mechanical output or the engine. If such an engine is powering a generator, then the electrical output is likely to be 85% of the mechanical input to the generator (depending upon generator efficiency). This would yield an overall efficiency of about 27% -- a bit lower than the figures you quoted, but I am thinking in terms of very small (portable) diesel generators. Some huge diesels are much more efficient.
Good Answers: 19
08/18/2008 1:54 PM
Correct, I had neglected the generator efficiency.
I was using a "rule of thumb" from an old college prof, that 30-40% of engines fuel is converted to useful work, 30% +/- lost through exhaust stack, 30% +/- is engine cooling, and 10% +/- is unaccountable losses. This is engine shaft output and does not factor in the driven equipment losses.
Thanks for the correction!
08/19/2008 10:34 AM
I do not wish to appear pedantic, Ken........but units are l/kWh..........not l/kW/h, I mention this only because, if someone wanted to carry out any calcs, incorrect units can cause a problem.
Good Answers: 247
08/19/2008 6:02 PM
Funny you should mention it. Actually, what I'd intended to write was g/kW/h, not ml/kW/hr. Mathematically, g/kW/h is the same as g/kWh (just as 32 feet per second squared is the same as 32 feet per second per second.)
I searched around to see if I could find any support for my logic, and found only this, where BSFC is expressed as .39lb/hp/hr (instead of .39lb/hp.hr). I prefer the .39lb/hp/hr (or the rough equivalent 240g/kW/hr) but only, I suppose, from experience flying. There, you see gauges reading in pounds per hour or gallons per hour. So then it seems natural to think of lbs/hr/hp I suppose.
With some struggle, I found this textbook, which suggests that the x/y/z logic is preferred. I suppose if you are thinking "how many units of fuel does this engine use per hour when it is producing 10 hp" then the x/y/z/ logic makes sense.
But in any case, I think you're right -- most manufacturers use g/kWh rather than g/kW/h.
An after thought (i.e., rambling even more): I suppose it has to do with thinking in terms of power or in terms of energy. If you are thinking "how much fuel flow will produce 40 kW of power", then the x/y/z logic makes sense. If you are thinking in terms of energy: "how much fuel will produce 40 kWh of energy" then the x/(y*z) logic makes sense. Either way, the calculation comes out OK, if you keep your wits about you: 2/2/2 = 1/2 2/(2*2) = 1/2
Re: Calculating Diesel Consumption in DG While Running in Full-Load
08/17/2008 6:30 AM
The basics of this was discussed in a thread a short time ago. In short, either use a flow meter and time over a given period e.g. 15 mins or use a snap tank for accurate consumptions.
08/18/2008 4:00 AM
On-site testing is really the only way to establish this information.
Register to Reply 11 comments
Blink (3); MOBI (2); prakash_venue@madhuri.com (1); PWSlack (1); Ried (2); Shawn_V_Elect (1); Sparkstation (1)
You might be interested in: Fuel Testers, Water Pumps, Centrifugal Pumps
