Previous in Forum: Digital Meters vs. Analog Meters   Next in Forum: Measuring Coal Flow
Transformer Size
08/18/2008 8:05 AM
Whats the typical size of a 400VA transformer?
Re: Transformer Size
08/18/2008 8:44 AM
About 8" (200mm) in diameter with a hole in the middle...
If its a toroidal transformer if it isn't it could be a different size...
08/27/2008 12:06 PM
300mm x 300mm x 300mm
01/05/2025 5:25 AM
The best thing to do is to search for vendors and look at the data sheets for them.
A 3000VA portable transformer is typically 300x300x400mm and 15-20kg not including its cable and connector plugs/sockets.
Register to Reply 3 comments
Electroman (1); martin (1); PWSlack (1)
