Previous in Forum: Recycling Credit Cards   Next in Forum: What Is CS Killed Material?
8 comments
Wanted: 12/24 VDC Vibration Sensor to Trigger Relay
08/21/2008 7:06 AM
Is anyone familiar with vibration sensors? I am trying to find/ use a vibration sensor to "turn on" another piece of equipment such that when Machine A's vibration reaches a certain threshold Machine B will be turned on via a relay to the coil. Any ideas would be greatly appreciated.
Re: Where can i find a 12/24 VDC vibration sensor that will trigger a relay?
08/21/2008 7:30 AM
How does the 'nudge' function in an electrical/electronic pinball machine work?
Good Answers: 140
08/21/2008 8:01 AM
Tilt sensors in old style pin ball machines, I have a Bally machine from the early 60s, work by way of a rod hanging down through a washer. At the bottom of the washer is a weight that can be set higher or lower on the rod. The weight is shaped like a cone. The higher up the rod the cone/weight is set, the smaller the amount of motion is required to have it swing so that the rod touches the side of the washer. When the rod touches the washer, a circuit is completed and the machine "tilts". Newer machines have motion sensors and weighted reed switches.
Some of the hardware in the old style machines is quiet ingenious.
08/21/2008 7:30 AM
Maybe one of those horrid cheap car theft alarms that go off in the middle of the night ?
Or make one with a strip of brass with a weight on the end and a contact, youll need a bit of circuitry to smooth and latch the output.... adjust the mass and length to tune it to your requirement...or a pendulum based one.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
08/21/2008 10:04 AM
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 74
Re: Wanted: 12/24 VDC Vibration Sensor to Trigger Relay
08/21/2008 2:06 PM
Here are some you may want to look at. And this article provides a selection guide.
Bruce
08/21/2008 11:51 PM
I think you may be able to get the sensor and solenoid from a boneyard by using an anti-knock circuit off the engine. You may have to experiment with a potentionometer in the signal line. Good luck.
08/22/2008 10:17 AM
I agree with all of the above, a Mercury tilt switch with a sensitivity adjuster may work also. You will need to "latch" the relay by maintaining the power to the coil through the contacts once they close.
The nice thing about Standards is there are so many to choose from.
Good Answers: 183
08/22/2008 1:16 PM
Any accelerometer is a vibration sensor. If you couple with a threshold detector you have what you want.
Register to Reply 8 comments
ba/ael (1); Bricktop (1); nick name (1); North of 60 (1); PWSlack (1); RPalmer62 (1); Tonymech (1); user-deleted-1105 (1)
