Previous in Forum: contiuous casting   Next in Forum: anti rust polytape
9 comments
vacume
08/24/2008 10:21 AM
procedure to create vacume?
Re: vacume
08/24/2008 11:13 AM
Remove everything else. What's left is a vacuum.
If you want a more useful answer, please indicate how hard you need the vacuum to be, how rapidly you need to attain that pressure and what volume you need to evacuate. Any other information you can give may help in getting you a sensible response.
Re: vacume
08/24/2008 12:18 PM
Place a cover with a Vacuum Gauge in the position over your lawn mower engine carburetor intake while it is running and you will see a Vacuum Pressure at the Gauge before the engine dies due to lack of atmospheric air.
You can also see an explanation on Vacuum at this web site in Chapter 1 starting in page 5.
http://www.hydraulicspneumatics.com/200/eBooks/
Look in the Basic Book.
Bud Trinkel
Good Answers: 97
Re: vacuum
08/24/2008 1:53 PM
If the vacuum is related to free energy try this.
www.youtube.com/watch?v=Fv2VUnBpK20
Disclaimer - My sound card is on leave (AWOL) and I cannot even say he is talking bull.
Re: vacume
08/24/2008 3:21 PM
If the system volume is small, several gallons or less, and primarily used for home experimentation, connect the suction tube of a used refrigerator compressor to the system and turn on the compressor. It will do a passable job of creating a vacuum.
Another approach used industrially is to install one or more water aspirator jets. The jet can be sized to evacuate a large system or a small one at fairly high rate; the vacuum will be limited to about 23 mm of Hg, the vapor pressure of water.
Mechanical vacuum pump systems can achieve hard vacuum in large systems if you have the $$$ to pay for the equipment.
With little to go on try this!
08/25/2008 9:00 AM
Fill container with steam, seal the container and then cool it! That will create a vacuum! It won't be a perfect vacuum but it may be just what you need!
Good Answers: 15
Re: With little to go on try this!
09/01/2008 6:21 AM
Hi Mr. Truman Brain, your lat long puts you at the SW corner of Britain (specifically by the cerne abbas man) not the SE corner of Spain!
09/01/2008 7:32 AM
As you'll no doubt discover, Mr. T. Brain is a tricky one!
09/01/2008 7:43 AM
Hello capblanc, I'm on the Cabo de Gata by Almeria! But England is in my heart always! Unfortunately, it rains too much so I'm here!
Re: vacume
08/26/2008 6:03 AM
According to the British Railways Rule Book 1950, the signal to create vacuum is given by the Guard, giving the Driver:
  • by day, a vertical movement up and down of the fist above shoulder height
  • by night a red handsignal moved vertically up and down above shoulder height.
BudT (1); capblanc (1); harralrw (1); Hendrik (1); JohnDG (2); Mr. Truman Brain (2); PWSlack (1)
