Previous in Forum: Plating Nickel on Chrome   Next in Forum: titration laboratory instrument
Over drying plant and instrument air?
08/24/2008 10:59 PM
As a process engineer working with utilities, I am always looking in optimization.
The facility I work in utilizes 4 desiccant dryers with varying product air temp dew points ranging from -110 to -70 degrees F.
I would like to establish "common practice" for a maximum tolerable air temperature dew point so that regeneration cycles can be based on dryer performance and not necessarily time. Where I work, the lowest recordable ambient temperature was -8 degrees F.
Thank you much!
-David
Re: Over drying plant and instrument air?
08/26/2008 3:28 AM
A global photographic materials manufacturer operated at -40degC dewpoint at its UK factory.
08/27/2008 9:42 AM
ok, so go back and calculate the dew point of compressed air. If you dry your air to -10 dew point at the meter, you will make water in your headed as sone as the outside temp gets to 35 F and it'll freeze at 32 F. The hygrometers are not set to measure water content under pressure.
The estimated dew point temp you need is about -50F, so the added security of -100F is worth it. One frozen line would cost you your job, is it worth saving $1000/year versus shutting down a unit?
Register to Reply 2 comments
