Previous in Forum: air conditioning question   Next in Forum: Trojan horse Trojan/Dldr.Small.bbn
carbon steel
09/03/2008 1:40 AM
Dear Sir,
Please,
1- what is the suitable materiales of piping from below for sulfaric acid in 30-40 deg c and cocentration(25% and less than 25%)
carbon steel, pvc,pe,hdpe,
2- what is the suitable materiale for piping to transfer and storge demi-water(boiler feed water at 12 bar and 30-50deg c ( carbon steel or s.s)
with my regard
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: carbon steel
09/03/2008 3:10 AM
1. Sulphuric acid behaves in a different way for different concentrations. Stainless steel should behaves good at low concentrations and even mild steel should behaves good at very high concentrations ( 98% and more ).
2. For demi-water transport the best behavior has stainless steel.
Look over to the next challenge
Re: carbon steel
09/03/2008 6:20 AM
http://www.coleparmer.co.uk/techinfo/ChemComp.asp
Think about plastics like PVDF for H2SO4.
Location: No. 1 Makiling St., Hacienda Heights Village, Conception 2, Marikina City, Philippines
Re: carbon steel
09/07/2008 7:38 AM
-1.0 what is the suitable materiales of piping from below for sulfaric acid in 30-40 deg c and cocentration(25% and less than 25%)
You can use either pvc or pe
use s.s for demi-water
LORENZO G. GALVEZ, Mechanical Engineer
Register to Reply 3 comments
lgalvezcorporation (1); PWSlack (1); user-deleted-1104 (1)
