Previous in Forum: Plastic pump/Motor components   Next in Forum: 3D Models of Universal Drive Shafts
17 comments
Determining keyway size for a shaft
09/04/2008 12:19 AM
Is there an industry standard, generally accepted practice or engineering formula for determining the size (width/depth) of a keyway and key on a given sized steel shaft. For example 1/2", 5/8" 3/4" and so on. Additionally the shafts would be threaded to accept the approriate sized threaded nut for the shaft.
Good Answers: 230
Re: Determining keyway size for a shaft
09/04/2008 2:48 AM
Hello fastener
You do not list your location or country, which may easily be done in your Member Profile, and it will autoupdate.
Yes, there are Standards for Keyways, but these are for various areas of the world:
http://www.roymech.co.uk/Useful_Tables/Keyways/keyways_BS46.html
http://www.baldor.co.jp/image/pdf/SHAFTKEY.pdf
There are others, look under Google Results 1 - 10 of about 136,000 for keyway standards. (0.21 seconds)
Please read about the present difficulties, here: http://www.technoflex.dk/default.asp?Action=Details&Item=233
Kind Regards....
09/04/2008 10:26 PM
U.S.A. Thanks for the help
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
09/04/2008 3:33 AM
Please follow this link www.tribology-abc.com/calculators/key.htm
Look over to the next challenge
09/04/2008 11:55 AM
The Machinerys Handbook (Machine Elements) covers American and British keyway standards. And if you don't have access to the Machinerys Handbook, well .............. that is an issue all in itself.
Good Answers: 21
09/05/2008 4:26 AM
I am in possession of Machinerys Handbook. Give me a valid e-mail address to send you.
09/05/2008 5:26 AM
I would appreciate if you can e-mail me the Machinerys Handbook. My e-mail address is elvis@bayupurnama.com.my or if the file is a large one, please send to this elvis_chong@hotmail.com.
Thank you in advance.
Good Answers: 21
09/08/2008 2:24 AM
Unfortunately, the document is too large, has 380 MB. Is not possible to send via e-mail. I will try to do a copy to a CD.
Kind regards
09/08/2008 3:15 AM
Hi Aurel Mares,
Someone has shown me the link http://mihd.net/e6g04j where I have downloaded the Machinery Handbook. Therefore I do not need the CD.
Thank you.
Elvis Chong
Good Answers: 230
09/08/2008 4:36 AM
Hello Elvis Chong
Your link is for download of AVS Video Converter - That's where it went.
Reply with
Kind Regards....
09/08/2008 9:42 PM
Hi Sparky,
That link was OK , I downloaded 27 Ed Machinery Handbook OK.
I would not have liked to copy all that from my paper version.
Cheers Garth
Good Answers: 230
09/19/2008 7:52 PM
Hello garth
I did eventually get the Download, thanks.
Here in New Zealand we are at the far end of a long thin pipeline to the Internet.
Kind Regards....
09/05/2008 6:29 AM
sahu.siva@gmail.com can you please send to this e mail ID I will be very thankful & it will help me.
Good Answers: 21
09/08/2008 2:25 AM
Kind regards
05/17/2011 7:16 PM
Dear Mr. AUREL MARES,
Pl. send me copy of the Machinery hand book
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Thanks,
DHAYANANHDAN.S
09/05/2008 8:43 AM
There are variations in depth and width due to the power being transmitted location and space available for the key etc.
But for square keys it is generally accepted for the key depth to equal 1/2 the square dimensions.
09/05/2008 9:17 AM
The range in shaft size will determine what size keyway you'll use.
There isn't any rule of thumb but there is a chart that that specifies what the acceptible size to use.
Good Answers: 97
09/06/2008 4:22 AM
ANSI/ANSE B94.19-1997
Register to Reply 17 comments
Anonymous Poster (1); bwire (1); dhayanandhan (1); Elvis Chong (2); fastener (1); garth (2); Janissaries (1); pintoo (1); Sparkstation (3); user-deleted-1104 (4)
You might be interested in: Shaft Collars, Line-shaft Spools, Threaded Inserts
