I want to give input voltage 300mv to adc input.But this
voltage is actually a drop across 500 ohm .
And the voltage measured at each point w.r.t. GND is very high about 240 volts .
Thats why I used the differential amplifier to measure the differential voltage across the resistor but I am not able to get the result.
The opamp output is very less .
can anyone suggest me how to measure this differential voltage?So that I can give it to ADC.
