Previous in Forum: Horse Power Calculator for Spade Drill   Next in Forum: arresting the washer or spacer in groove
Mechanical Sifter qualification
09/16/2008 9:07 PM
Hi guys,
What are the critical parameters to look for in qualifyng a mechanical sifter or sieving grading and straining machine?
Re: Mechanical Sifter qualification
09/18/2008 3:23 PM
depends on your product and quality needs as well as output.
As Johnny Five would say; more input please
09/19/2008 2:55 AM
but may i know common tests to be conducted?
09/19/2008 8:58 AM
that would require empirical information, I don't know if I can help you, I'll see what I have.
09/19/2008 8:59 AM
check this website you will get some idea. http://turf.lib.msu.edu/1920s/1922/2205155.pdf
09/19/2008 8:11 PM
actually i'm in pharmaceutical company. and i need to develop a protocol to qualify the sifter. and i have no idea about this machine.
09/24/2008 10:26 AM
Lacking knowledge about a machine is not uncommon, but it's not the end of the world either. I was once asked to qualify a machine I knew nothing about and this is how I approached it.
My first step was to read the proposal that the machine supplier provided us against the requirements my boss gave the supplier. Then I thought about the worse case the machine would see and to my surprise, my worse case was nothing compared to what the machine suppliers claimed to be capable of providing. So, I took the spec's from the proposal and told the supplier that his spec's were fine, then I held up his spec's and said we were going to test to his spec's and verify the machine could do what they said it could do.
In my case, the machine used up only 10% of the tolerance allowed by the suppliers own spec's. In the end, the machine performed perfectly for many years.
Good luck.... and let us know how it turns out.
Register to Reply 6 comments
jamiruqioe (2); Labyguy (1); network (1); phoenix911 (2)
