Previous in Forum: Insulation Cable   Next in Forum: Hermetically-Sealed Distribution Transformers
Level Measurement
09/24/2008 9:05 PM
Hi everybody....
i have 1 question to ask.....i hv some trouble to calibrate my level instrument.for your information , i'm a beginner in instrument field.so i wanna ask how can we know the actual level in the tank base on 4-20mA input.can any1 help me???..
tq
Re: Level Measurement
09/24/2008 11:50 PM
tell us more, to help you...
what height of the tank?
what density? process liquid / sealing liquid?
is a close tank?
distance between two nozzle, top and bottom?
09/24/2008 11:51 PM
this should be post under intrumentation not Electrical?
09/25/2008 1:13 AM
eeeeeebiddidddy ahhhhbbbidddddy iiiibbbbidddddy unk.
In = Out.
Try inserting a photo (worth a thousand wurdz) an a bunch of other data, an mebbe yule git sumpthin more then garberge bak.
Good Answers: 54
09/25/2008 8:52 AM
09/26/2008 9:14 AM
Put the transducer 24" up from the bottom of a standing pipe. Make the pipe tall enough to emulate the tank. Put a fitting for vinyl tubing and a valva at the bottom of the pipe and a clear tube attached to the outside of the pipe for it entire length or more. Fill the stand pipe with whatever is in the tank and as you let the liquid out of the pipe with tha valve located near th bottom, take instrument readings and stand pipe level readings from the sensor center line to the ligiud surface in the stand pipe for comparison in about twenty or more near equal steps across the expected range of the tank. These readings may or may not be linear and this is the only way to be sure of what gauge output is compared to the liquid level.
09/26/2008 7:43 PM
tq to all...
i think i have little bit understand wat you try to explain...
Register to Reply 6 comments
