I wasn't quite sure where to post this, but believe the problem is software related.
My problem is my laptop, connected via ethrnet, does not talk to my router. Everything was working fine, but then I lost my connection, and have not been able to re-establish it. I often take my laptop with me, and plug / unplug the cable as necessary, but now I can't connect. I get an error staing "Limited or no connectivity"
Both the laptop and router are set-up for automatic DHCP, but the laptop does not accept the IP the router tries to assign it. None of these parameters were changed, though I've tried changing them since in an effort to get the bloody thing to connect.
I have a HP Compaq nc6120 (running XP Pro)with a Broadcom NetXetreme Gigabit Ethernet card and the router is a Linksys WRT45G2. The router does not have internet access; I use a cell modem card for that. We also have one other laptop and a network printer on our small system, but they work fine. If I move my laptop to the other know working connection, I get no results, so I suspect the problem lies with my laptop or the software in it.
I have attempted to reset the router and the laptop several times, but it does no good. Using ipconfig, I see that my machine is not establishing the proper IP addresses to work. The linksys IP address is 198.162.1.1, the default for the unit, and the assigned address should be 198.162.1.100 or higher. From ipconfig;
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\user>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : snbcfasgfnv
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : Yes
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : 00-14-38-0E-0A-40
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.24.45
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 169.254.24.45
PPP adapter Sprint Mobile Broadband - Pantech:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 70.6.63.19
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 70.6.63.19
DNS Servers . . . . . . . . . . . : 68.28.58.92
68.28.50.91
NetBIOS over Tcpip. . . . . . . . : Disabled
I've tried reseting windows IP and winsock, but it yeilded no results. From the other laptop, I've gone into the linksys router. It has a window which reports active IPs t for the router. I can see that an address was issued for my computer name (with MAC address), yet my laptop does not use it. I found an article in MS describing registery enteries for TCP/IP, and have even gone as far as to modify the registry to put known working IP addresses, submasks, etc., but still could not get it to talk again. I tried pinging from the laptop, and could not do so - it times out. If I use the working laptop, I can ping the printer and router.
I've updated the driver for the Broadcom card. No good.
At this point, I've tried everything I can think of, and I want to curse, drink, or both.
