Previous in Forum: firewire camera for machine vision   Next in Forum: for a projects
12 comments
Popular Science - Genetics - India - Member - New Member Popular Science - Biology - Member Technical Fields - Education - New Member Hobbies - Musician - New Member
Urgent!!! Midpoint of Arc formula
09/26/2008 3:24 PM
Hey...
Can anyone give me the formula of the mid point of an arc??
I have the coordinates of the 2 ends of the arc (spherical ie. the coordinates are in xyz)
The center is origin.
Now, there are 4 such possibilities.... unless i have one more parameter...
I have a point that the radius passes through but it lies inside the sphere... I need the exact point on the sphere.
Thanx
Whenever I find the key to success, someone changes the lock
Pathfinder Tags: arc circle maths mid point Sphere
Good Answers: 97
Re: Urgent!!! Midpoint of Arc formula
09/26/2008 3:48 PM
in 2D
Anywhere on the line going through the mid point perpendicular to the line. (assuming homework I stop here)
You would need another point or a radius to fix it to a point.
09/26/2008 4:24 PM
Nah in 3D...
And i tried to look up extending a ray but no equations are available.
It is amazing how most softwares do it so easily.. the equations are hard to find.
the point lies on a polyhedron in the center of the sphere.
09/26/2008 4:54 PM
Good Answers: 97
09/26/2008 5:27 PM
Definitely not homework.
What about using x² + y² + z² = R² ? but you would need R and a third point.
09/26/2008 9:00 PM
absolutely a homework of a middle school student.
you hve list sphere surface equation. and have two points. the midpoint coordinates is very evident.
Good Answers: 97
09/26/2008 6:00 PM
With centre point and radius known
Mid point C =
xa + (xa - xb) / 2 , ya + (ya-xb) / 2 , za + (za-zb)/2
Point X can then be calculated by extending the vector Centre - C up to the radius.
Good Answers: 97
09/26/2008 6:31 PM
I desperately need glasses. But I am standing because I cannot sit down for a long time.
You could go polar - determine Θ in the xy plane and then α in the z direction.
Xx = r Cos Θ
Xy = r sin Θ
Xz = r cos α
Good Answers: 143
09/26/2008 7:34 PM
09/27/2008 10:05 AM
Write the parametric equation line thru "o"and "c",(at;bt;ct),look for the "t" for interjection line with surface sphere,put this value in the obtained line equation,now you got a point what belongs to the line and to the sphere (two points).-
09/27/2008 12:32 PM
The mid point of the arc cord is most easily given by adding the x's and dividing by two. Same for y's and z's. Then extend the ray from the origin through this point distance R.
That part of the problem reduces to solving two similar triangles which can be done using trigonometry or Pythagorius's theorem. I like Pythagorius. By substituting the mean coordinate point formula into the Pythagorian formula and working hard on the algebra you should be able to reduce the result to a single line that gives the R(x,y,z) of the tangent point of the spherical arc segment. I'm not interested enough in your problem to do the work for you.
09/29/2008 3:20 AM
First off the radius of the sphere is R = SQRT(x12+y12+z12) OR SQRT(x22+y22+z22)
Now the coordinates of the mid point of the line between the two points is
(x3,y3,z3) = ((x1+x2)/2,(y1+y2)/2,(z1+z2)/2)
If the length of the line to the mid point is L = SQRT(x32+y32+z32)
Let the ratio of radius to the length to the mid point be k = R/L
Then the coords. of the mid point of the arc are (kx3,ky3,kz3)
Have I missed the point here (no pun intended)?
09/30/2008 11:55 AM
The easiest method is, to use polar coordinates.
Assuming you use a coordinate system, which has its origin in the middle of the circle.
Then the equation of the circle is x^2+y^2=r^2
with x= r*cos (phi) and y = r*sin (phi)
you need to know only phi of the midpoint of the arc.
Use the coordiates of the two points, which you know and calculate their angles
alpha and beta
with xA = r*cos(alpha) and xB= r*cos(beta), you get alpha and beta, by using the inverse functions
alpha = arcus cosinus ( xA/r) and beta = arcus cosinus ( xB/r)
Subtract the angles and divide them by two:
(Alpha -Beta)/ 2 = phi
Put phi in the first two equations above and you have the coordinates of the mid point of the arc.
regards
Claus
Register to Reply 12 comments
Anonymous Poster (2); cnpower (1); ferquiza (1); Hendrik (4); Mrinny (2); Randall (1); TVP45 (1)
