Previous in Forum: Saving Fuel While Driving Downhill   Next in Forum: Fuel Saving Kits
9 comments
Oxygen in Gasoline/Petrol
10/08/2008 11:22 AM
If oxygen supports/enhances burning, what would happen if oxygen crystals like Oxy- Clean is added to the fuel tank of a car. Would the crystal desolve in gas/petrol and would it become oxygenated. This is somthing I am unwilling to test as if the crystals do not desolve, it may contribute to unwanted wear in the engine, I guess. What do you all think of this?
Good Answers: 101
Re: Oxygen in Gasoline/Petrol
10/08/2008 5:04 PM
I would not try this in any of my engines. My guess would be this: any oxygen disolved/released by the crystals would essentially dissipate into the air, not the gasoline. If you want more oxygen in your Internal Combustion Engine, it needs to be intorduced as a gas, such as NOS.
Oxy-clean is a sodium percarbonate (C2H6Na4O12) detergent and bleaching agent which produces hydrogen peroxide when dissolved in water. Seems to me all that other stuff would not be worth the oxygen that may be released.
I'm no Chemist by any means, so as a science experiment, it might be fun to take an old lawnmower motor and dump some in the tank and simply see what happens. Thats where the fun stuff really happens anyway.
10/08/2008 11:42 PM
take the blade off first
Canada - Member -
10/10/2008 2:53 PM
But be careful: some lawn mowers need the blade to regulate the speed of the engine. Without it, it revs up big time.....
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
Good Answers: 143
10/08/2008 7:59 PM
If your car is well maintained, it already gets enough oxygen for stoichiometric burning. The only thing extra oxygen would do for a normal car (engines that require 3 or 4 gallons of petrol a minute are a different story!) is overheat it since you would not have the cooling nitrogen present.
10/09/2008 7:09 AM
Find something useful to do..........this is not a useful idea, sorry.
10/10/2008 12:08 AM
In my experience, adding chemicals which readily give up their oxygen to volatile hydrocarbons can be very entertaining as long as you're not sitting on top of or near the sealed container. You'd be lucky if all it did was ruin your engine.
Gordie
10/10/2008 12:18 AM
Saw a guy pour muriatic acid in a Pepsi and screw the top on then throw it.
When it hit the ground it went off like a bomb. Strangest thing I ever saw.
Good Answers: 12
10/11/2008 10:57 PM
Oxygenated fuel means that they add alcohol to the fuel like C2H5OH (ethanol).
Aint no way I would subject an engine to Oxyclean.
Bill
10/24/2008 1:42 PM
so the excess oxygen only leads to overheating and the only sensible way to provide it in case of an engine that can use the excess is as a gas and not as an additive in the fuel??did i get that right?
feel free to ignore my next question since it is not productive by any standards.
Q:if one has a commonplace engine and can provide the required cooling externally would there be an gain by following this idea??also i think the original question was "crystals like oxy-clean".so are there any other products that might work as a fuel additive if the answer to my first question is something positive?
pineapples hate me.its ok i dont fancy thm that much anyway.
Andy Germany (1); Anonymous Poster (1); dadw5boys (2); Rick@cae (1); RVZ717 (1); Sciesis2 (1); shanky1367 (1); TVP45 (1)
You might be interested in: Optical Crystals, Dissolved Oxygen Sensors, Crystals
