Previous in Forum: Alcohol Storage Tank   Next in Forum: Welding imperfections
Bagging Conveyors
10/15/2008 4:14 AM
Hi,
I am a Maintenance engineer at a bagging plant for Urea.
We have a number of bagging conveyors which are used to feed the bags towards the trucks which are manually loaded by workers.
Once these urea bags are moving on the conveyor belts the Idler rollers tend to get jammed very often due to:
1) Threads (used for stitching the 50 kg WPP bags) getting stuck in the rollers
2) Urea going inside the rollers.
These jammed rollers also cause the conveyors to detrack .
If someone has any experience of using side travel rollers or scrappers ( wipres) please do share your experience with me in detail.
Regards
Good Answers: 266
Re: Bagging conveyors
10/15/2008 7:57 AM
Most bagging conveyors have covers over the ends of the rollers of the bed to reduce contamination of the bearings on the ends during spills, funneling it to the floor. Are these in place as they would also help keep the thread from the stitching from wrapping around the axle shaft.
Also the stitching machine is it leaving too long of a tail? Adjustment to this may reduce the thread problem.
How about some pictures so that we can better see what you are dealing with?
Re: Bagging Conveyors
10/15/2008 9:50 AM
Contact Mike Anderson of Portec Inc rep in North Carolina. If does not know, he'll point you in the right direction.
mikeand@worldnet.att.net
Another bunch would be Jervis B Webb Company engineering team in Farmington Hill, Mich.
India - Member - ROBOTICS Engineering Fields - Marine Engineering - New Member;I believe in integrating several disciplines of engineering.
10/16/2008 2:32 AM
Hi Guest:
Please visit www.artecrobotics.com and view under "Products" a Robotic system for truck loading/unloading.Although demonstrated for handling LPG cylinders, it is adaptable for handling 50 Kg. X 10 bags at-a-time. It can place individual bags in different positions and orientations on the truck.
This system can eliminate dependence on whimsical labour sub-contractors who have the potential to cripple operations being at the final product "sale" point. A unit can also be offered for handling the bags coming off the filling carousel/stitching unit and eliminate the troublesome conveyors. The whole system is synchronisable with the production output and despatch operations, and seamlessly integrate to the MIS.
Having conducted a detailed survey of one of the best Fertiliser plants in India for induction of Automation of Process control and operations, a certain extent of familiarity and experience can be brought to bear on the problems in a cost-effective way.
Regards
D.Ramakrishna Naidu
Design & Build HOMOPHILIC Suprahuman ROBOTS
10/16/2008 12:34 PM
cover your conveyer belt upper layer with rubber conveyer belt or thin wire mesh conveyor belt so that the bag threads or urea powder wont go thru it ,if u need supplier for that i will refer it to you ...mail me back with a picture attachement of your conveyor system at metalmasterengg@gmail.com
shamsher singh (mech engineer manufacturers)
D.RAMAKRISHNA NAIDU (1); dc8forever (1); metal master engg (1); ozzb (1)
