Previous in Forum: push button motor starting   Next in Forum: level measurement
Level transmitter calibration range
10/19/2008 9:15 AM
Hi to all,
I'm new here. is it possible to calculate calibrated range of LT w/o knowing max level of the tank? given is only the height of Hi & Lo distance. for instance I'm using a diaphragm seals in a closed tank. can anybody give a sample calculation? what is the capillary seal fluid specific gravity? is it standard on all capillary Tx?
thanks in advance. sam921
Good Answers: 54
Re: Level transmitter calibration range
10/19/2008 7:32 PM
Hi sam921,
Check out my answer to a similar question
http://cr4.globalspec.com/comment/160898
regards,
Vulcan
10/19/2008 10:36 PM
Hi,
If I understand your question correctly.Yes it is possible
"The older I get -The better I was"
10/21/2008 1:51 AM
ye it is possible to calibrate the LT without knowing max level of the tank.the distance between the hi and lo diatance should be the sapn of the LT.
10/23/2008 3:47 AM
check the installation manual ,of capillary type DP XMTRS you will get the exact density of seal liquid ,rest everything is fine
regards
find2 am
Register to Reply 4 comments
Anonymous Poster (1); karthickranii (1); Vulcan (1); wrenchpuller (1)
