Previous in Forum: PC board rack end-plates??? I don't know what to call them...   Next in Forum: Faster Than The Speed of Light! I've Found It.
Rotatable Gripper for Paper Tubes
10/23/2008 11:04 PM
i need to grip a series of 15 card board paper tubes of dia 15 mm length 2" in a series placed with inter distance of 30 mm each. all have to gripped independently and need to be rotated to allow for a crimping process to take place and have to be released after the process is over. the machine is electric driven. are there any product (mini electric driven gripper allowing rotation) - ready made off the shelf product available. thanking you, s.srinivasan
s.srinivasan, falcon engineering works, sivakasi. india
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
Re: rotatable gripper for paper tubes
10/24/2008 12:04 AM
I have used conical and inflatable end inserts...
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
10/24/2008 12:12 AM
if I understand you, try doing a search for an iris type gripper
Good Answers: 183
Re: Rotatable Gripper for Paper Tubes
10/24/2008 4:00 PM
Try Schunk
10/29/2008 12:44 AM
Have you considerd vacuume?
10/29/2008 1:31 AM
You didn't specify as to how you wished to hold your part (sides, ends, internally) or your desired process direction (where and in which direction is the crimping). Also you didn't specify the wall thickness of the tubes you wish to process. Variables such as these often dictate what type of holding fixture you use. In the past I've often used vacuume for light parts in clean environments. It actually has surprising holding power on even delicate parts with no deformity if your fixture is well designed. While air pressure is often also a common and usually acceptable form of gripping a part if not properly designed it may deform the part in question. However if you were gripping from the inside then I would opt for air pressure. probably a pnumatic cylinder drawing down on a mandrel compressing an elastomer bushing forcing it to expand to the interior. Easy to set up and adjust for various loads and delicate parts or more agressive processes.
Anonymous Poster (2); nick name (1); phoenix911 (1); ronald (1)
