Previous in Forum: need help in designing a contact pressure sensor.   Next in Forum: Slope Mower
18 comments
Plastic Springs?
11/02/2008 10:16 PM
I am trying to eliminate compression springs in our product that provide an electrical connection between a printed circuit board (pcb) and several metal tilt switches that can not be soldered. The idea is to screw our pcb into our plastic frame and have the metal tilt switches (held by the plastic frame) press directly against the pcb gold contact pads. To do this the tilt switches are held by .5" long, .035" thick, plastic flexures that yield ~.015" when the pcb is screwed down to the plastic frame.
Our rapid prototype sla seemed to work well for a while, then electrical contact was lost - a lessening of compression force provided by the plastic flexure is suspected. The sla is not the ABS we plan on using for the final product, but right now this approach seems like a bad idea, especially since we hadn't even subjected the prototype to the temperature extremes the product will experience.
However, the benefits of the design are very compelling costwise in parts and assembly. To succeed we will need plastic material that does not soften at 100C (thereby giving up compression) and is not brittle, so it can flex to the small degree needed with a flexural modulus not too much greater than ABS.
Any ideas for the right plastic material?
Anyone done anything similar with success?
Re: Plastic Springs?
11/03/2008 12:05 AM
If you are planning to use plastic springs, the springs should have no deflection in the normal position. A plastic spring is good for deflection with the resulting force for a short duration, such as pushing a key on a key pad. If a plastic spring is under a constant load, it will eventually live up to its name "plastic" and deform. ABS is not as good as acetal (Celcon) for plastic springs. Personally, I have used plastic springs in many designs and have fournd them to be effective, providing, that they are used properly. I hope that this suggestion helps you.
11/03/2008 1:54 AM
Most plastics creep under load, so must have a normal condition of zero or close to it, load. In addition, temperature dramatically increases this effect.
Polypropylene may do it but I suspect the 100C temp will beat it.
Some of the nylons may also work, but again temperature may reduce it's life.
Some of the thermosets may be your best bet.
You could look at phenol formaldehyde, urea formaldehyde.
I assume this is to be a production part, so cost will be impotant.
You will probably need to fiddle with fillers (glass etc) to get the right properties.
Good luck
United States - Member - New Member Popular Science - Weaponology - New Member
11/03/2008 10:55 PM
I agree with ronsargent about the use of acetal AKA Delrin. I have designed some very interesting springs to use for actuating a pixi-point without damaging it. It is easy to adjust the tension by adjusting the thickness. There are no materials yet available for use with SLA models that will give you the characteristics of a machined or molded part. Also ABS is definitely not the material for a spring. If you need a material that will withstand a lot of heat, then you might want to consider one of the polycrystalline materials. I don't remember the names, but they shouldn't be hard to find. I used one that was carbon fiber filled for a snap on assembly that was subject to 200+ degrees. The material had a 500deg. molding temperature so the heat was not a problem.
Men are like steel, if they lose their temper they are worthless.
Hobbies - Fishing - Zoomer
11/04/2008 9:32 AM
I think one of the materials Garyceng is thinking of is an LCP, like Vectra. The main problem I see with making the springs one piece with the frame is that the best material for the frame may not necessarily be the best spring material. ABS is definitely not a good material for a spring that is under constant load. Without knowing details of the overall design and requirements, it is hard to recommend a material.
When in doubt, do it the right way.
11/04/2008 12:01 AM
send us your detail with the drawing on www.cgenterprise.in we can give some better information for the same.
11/04/2008 4:16 AM
First, let me say that I have no knowledge or experience in this area so just ignore me if I'm being stupid.
What about cutting "fingers" in the PCB and letting the FR4 do the flexing.
11/04/2008 10:56 AM
Not stupid at all! We considered this, but a primary consideration is space. This is small assembly of about 1" total and there is no room for the 'fingers' on the pcb.
Thanks,
Dave
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
11/04/2008 8:11 AM
What about plastic coated metal springs?
If necessity is the mother of invention then is laziness the mother of necessity?
11/04/2008 8:12 AM
I'd go to DuPont, GE Plastics, ICI or any large supplier and ask the guys who REALLY know their products.
Good Answers: 53
11/04/2008 8:12 AM
Don't undersatnd exact application you discribed, but just for your information PU springs are beeing widly used in press tools, and work better then metal one,
Good Answers: 94
11/04/2008 8:23 AM
Good Answers: 37
11/04/2008 12:26 PM
Good answer (and so rated). Another possible approach is use of conductive epoxy or similar adhesive, eliminating need for deflection. This is highly dependent upon layout, components themselves, and volume, though. Frame would only need to position switches initially.
" Ignorance and arrogance have more in common than their last four letters. "
Good Answers: 37
11/04/2008 4:00 PM
Follow-up: this came in a different newsletter that I just saw: http://www.cotronics.com/vo/cotr/ea_electricalconductive.htm#125. Look at the data sheet.
11/04/2008 8:39 AM
Stop trying to give the world another cheap oiece of garbage that will fail two weeks after purchase. Use proper metal springs and proper electrical contacts.
11/04/2008 9:00 AM
Cheap to build doesn't mean poor performance/reliability. If you think about the design he's described; assuming that he gets it right: it should be simple, and, therefore very reliable.
11/04/2008 11:18 AM
We currently use silver plated berrylium copper springs. They work well, but are very small, hard to handle, costly, and take up valuable space. So, we are exploring a lot of different approaches. Since product reliability/durability is priority #1, we may end up with the metal springs again if we fail to imagine/create something better.
11/04/2008 1:00 PM
Since reliability is the #1 issue, possibly staying with the beryllium copper springs, but mold them into the frame. A molder that does overmolding could mold over the pre-formed springs that come all together on a strip or sheet. Then the metal could be pierced to make them electrically isolated. If it is high volume, the springs could be supplied on a strip on a reel. The strip of springs would be fed into the mold, the plastic molded around it, the connections between the springs pierced, and either the carrier strip cut off and parts drop into a chute, or the assembly wound onto another reel.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
11/05/2008 7:52 PM
Hi, Non-ME!
Would a spring configured as a plastic plate with a flexible center work?
The plate can be made in any size/shape with any sized perimeter 'frame' to maintain the distance required above/below the spring contacts; and that distance would ensure a long-term usage life for the flexible portion so long as your plastic material has a low creep coefficient. Hmmm. Maybe not, considering that you still haven't found the plastic that is work wear and temperature resistant yet. Still, an idea.
Mark
Register to Reply 18 comments
Anonymous Poster (3); double_j_b (1); garyceng (1); MarkTheHandyman (1); Nigh (1); Non-ME (2); rakesh_semwal (1); Randall (2); Ron (2); ronsargent (1); sceptic (1); Zoomer (2)
