I have two fuses in an electronics circuit which includes a motor. One fuse is labelled T4AL250V and is on the incoming power supply. The other is on the circuit board itself and labelled T2AH250V. I know V is volts and A is amps. What does the L and H designate? I've read that slow blow fuses are used on motor circuits where initial start-up power diminishes rapidly. Does that have anything to do with the designations? It also seems these may be non-United States protocol.
