Previous in Forum: Anchor Load   Next in Forum: Air Conditioner Room Formula?
Preferred Velocities for Check Valves
11/14/2008 1:58 AM
One of our clients keeps breaking the springs on a Double door check valve on a Multiple Pump installation. Double door check valves need a certain velocity to ensure that the discs are kept open without "fluttering". If this occurs the springs can experience work hardening leading to failure.
Does anyone know what minimum velocity is required by double door check valves to ensure this does not occur ?
A passion for Life and Hydraulics
Good Answers: 183
Re: Preferred velocities for Check valves
11/14/2008 8:41 AM
Could you give more details? A valve cut away will help since the function and fluttering are depending on valve design. Fluttering will occur when the valve as flow at limit pressure is not matched to the flow which limited in pressure. It is usually due to the effect of flow forces which try to close in some uncompensated designs.
11/14/2008 10:22 AM
You may be able to approximate with the formula for tilting disc checks from Flowserve:
http://www.flowserve.com/vgnfiles/Files/Literature/ProductLiterature/FlowControl/AnchorDarling/ADAMS8007-00.pdf
min vel (ft/s) = 24·√
where is the the specific volume of the fluid (ft3/lbm)
Re: Preferred Velocities for Check Valves
11/17/2008 8:08 AM
This is a typical problem with DDCV's. To resolve this, the valve manufacturer can supply replacement springs that will meet your service conditions. Just contact one of their Application Engineers to select the spring that you need. It will be a lot easier to replace the spring than to play around with adjusting flow and line pressure.
03/26/2011 11:23 AM
Dear Mr.Pete,
The Viscosity and Density of fluid plays a vital role.
The opening force is derived from the kinetic energy of the fluid used, during flow due to pumiing. The valve has to open against the pressure due to Static Head and hence the STIFFNESS of the spring should match the pressure created by Static Head.
Thanks,
DHAYANANDHAN.S
Register to Reply 4 comments
A11an (1); Anonymous Poster (1); dhayanandhan (1); nick name (1)
You might be interested in: Check Valves, Gas Valves, Hydraulic Valves
