A 52Y anti-pump relay is in electrically operated circuit breakers and it stops a close-open-close "pumping" situation if the breaker close signal is continuously held on when the breaker is kicked open.
A pumping breaker can cause a pretty good adrenaline shot, especially if it's part of a paralleling system and shoots off puffs of green smoke every time it hits.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Thank you very much for your note. I really do appreciate it as I have spent much time reading your well thought out and informative responses on this forum. Let me take this opportunity to say that your insight and professional mannerisms in this environment are of significant benefit to others here.
Thanks
apart from above anti pump relaY PREVENTS continous power feeding to closeing coil in the absence of this realy closing coil will wil burn( because of short time rating of coil)
