Previous in Forum: water treatment   Next in Forum: Heat Transfer Coefficient
17 comments
Stainless Steel Grades 304L vs. 316L
11/30/2008 11:40 PM
Want to make comparison between 304L and 316L in food processing container. Which one is better for holding of drinking water.
User-tagged by 1 user
Re: stainless steel grade 304L vs 316L
11/30/2008 11:55 PM
Depends on the exact nature of your water -
http://www.force.dk/NR/rdonlyres/DB5F3C67-8CB3-44EC-BBEC-12DDCA539D0C/1852/NACECorrosion2008Unusualcorrosionfailuresofstainle.pdf
(of course 304L will be better due to lower cost if your water can handle it)
12/01/2008 12:02 AM
drinking bottle - like handling juice, milk and distilled water etc.
12/01/2008 2:58 AM
Structures in both materials are used to contain potable water. Please define the parameters of the word "better".
12/01/2008 8:44 AM
My "better" means more durable, washable in dish washer, lower leaching rate on both Chrome and Nickel since I understand Nickel is toxic stuff.
Hobbies - CNC - New Member Hobbies - Musician - New Member
12/02/2008 2:41 AM
...then i would go for 316L, has better properties than 304. (cost excluded)
Think and move like an electron
Re: Stainless Steel Grades 304L vs. 316L
12/01/2008 7:46 PM
The choice of 304 is best provided this water isn't DI (Deionized) or an injectible grade. The result will turn the wetted part of the vessel to a tea or rusty color, which can only be cleaned by a rather expensive chemical passivation process. This is a common problem for pharmacuetical manufacturers.
If cost is the issue and this is drinking water look into some of the plastic vessels or fiberglass with polyester vinyl resin liners, which are USDA approved.
12/01/2008 11:01 PM
The 316L is a food grade stainless steel. My company has made food grade stainless steel products for some time and 316 has always been the spec.That would be my choice.
12/02/2008 12:11 AM
316 has been used for decades in photo processing equipment. The molybdenum content increases corrosion resistance to photo chemicals, base and alkali. 304 used to be the no brainer for food handling.
EJay
12/02/2008 9:55 AM
We manufacture machinery that processes fruits and vegetables.
We use 304 for all our food contact. We use 304 for all our water flumes, some of which have a high chlorine content of 3%.
I have the feeling that 316 is a bit overkill.
12/02/2008 3:09 AM
In terms of corrosion resistance in potable water there is no difference between the two materials. The problem could be if there is a high concentration of chloride but I think that in potable water this should not be an issue. The limit for 304 is approx 200 ppm while for 316 is approx 500-1000 ppm. 316L will be a better choice if your plant is located near the sea or area with high chloride content in the atmosphere.
Stainless-steel piping can be cost-effective for potable water use.
corrosion prevention & protection
12/02/2008 3:15 AM
316L
12/02/2008 5:21 AM
If its simple water SS304L or SS316L both will do.
12/02/2008 8:12 AM
CRES 304(L) is the better choice as the cost and fabrication will be less expensive and since you are only containing drinking water the extra corrosion resistance will not be required.
You reap what you sow.
12/02/2008 1:09 PM
"food processing container. Which one is better for holding of drinking water."
Your question is not clear. Are you talking "food processing" or "food storage"? If the former, then either will work, as in boiling, cooking, etc. If the latter, then the 316L would be the better choice, assuming a long term storage
Mr.Ron from South Ms.
12/02/2008 2:53 PM
Container for drinking water, juice, and the like etc....
03/01/2011 12:30 PM
Thanks so much for the discussion of the stainless steel is very helpful
Register to Reply 17 comments
Anonymous Poster (7); BillV (1); EJay (1); Janissaries (1); madness (1); mikechiu (2); PWSlack (1); ronseto (1); strider6 (1); Used Guy (1)
