Previous in Forum: Troubleshooting an HP 3455a Digital Voltmeter   Next in Forum: HART Pressure Transmitters
10 comments
Speed Sensor for Siemens 84.2
12/12/2008 1:17 AM
We are facing the frequent problem in Equipment of Siemes V84.2 !
We need to change speed sensors evey year! It seems not normal ! This type of speed sensor was used many years ! So we would like to find other mark's speed sensor to try ! We only know this type of sensor can transform " Square wave " , can anybody please suggest for the possible sensors ???
If anybody havinf the experience with this sensor , please share the troblwshootings !
many thanks and with best regards,
MoMo
Good Answers: 54
Re: Speed sensor used in Siemens 84.2
12/12/2008 9:10 AM
What kind of damage are you seeing? Is the sensor physically damaged or just stops functioning?
Most times, I find that a failed sensor is due to something physical was done to it. Like an operator trying to open a valve by hitting it with a pipe and missing...oops! 'Gotta call the instrument guys!
It's also possible that your sensor's power supply is a little too high. Not enough to fry the sensor immediately but just enough to kill it in a year's time. Still on the power supply, you might also have occasional voltage spikes.
If your sensor is directly driving a relay, that might also do it in. The voltage spikes from the coil as it switches off will kill it if you don't have spike or surge suppressors (a simple diode will do).
That's about all I can think of at the moment. Let us know what you find.
regards,
Vulcan
01/12/2009 3:52 AM
Hello Vulcan ,
Thank you for your help !
Now we need to find the replacement for this type of speed sensor , because the selling price is higher than last year, increase about 60% , it's too expensive for our factory !so please let me know what type of speed sensor and maker for our reference!Thank you !
Momo
Good Answers: 54
01/12/2009 6:38 AM
I am not familiar with the Siemens 84.2 so I wouldn't know what sensor you've got.
Do you know what type of sensor it is? Do you have the sensor's brand and model? Can you post a picture? Any information might help me identify it
Don't wait another month to reply, please.
regards,
Vulcan
01/12/2009 8:38 AM
Sorry for my late reply!
Now it's our annual repair season ! The type is A5S05WE90 , maker is BRAUN !
In our factory this type sensor need to chang evey 2 years!
Hope this will be helpful !
kind regards,
Momo
Good Answers: 54
01/15/2009 7:17 AM
I thought I had already replied. Apparently, I didn't click on the "submit" button and closed my browser directly.
Anyway, the Braun A5S05 is a Hall-effect proximity sensor. I checked my favorite proximity sensor brands but none of them carry a comparable sensor.
I've successfully used IFM Efector and Pepperl & Fuchs speed sensors but in my case, I used their own modules as well. If you want to replace your unit, you may have to change the module as well as the sensor.
Check out the IFM or the P & F websites to look at their products. Alternatively, you can contact their representatives there in your area. The website will be able to give you their contact numbers.
Good luck.
regards,
Vulcan
01/15/2009 10:28 PM
Thank you Vulcan , I will check theses 2 others makers' sensor ! Hope we can solve the problem soon !
Once againt thank you for your kind help !
Have a nice weekend!
Momo
Re: Speed Sensor for Siemens 84.2
02/14/2009 6:15 AM
IFM Efector and Pepperl & Fuchs speed sensors can be used. If you application in rotating m/cs like motor you put encoder it will alos give the sine wave
Kubbler , buffale , TWK gemany, sensor
S.Pathan India
02/25/2009 7:44 AM
Thank you M. Pathan for your kind message ! But we are still check theses 2 other makers' sensor , because my boss afraids if it's not work it will make terrible effet , so .. I still try to talk with him ! but thank you for your kind advise !
Momo
02/26/2009 12:28 AM
Dear
Can you tell us what is your application for this sensor used. Normally these square waves have pluse how many you need , range of sensor, input volatge required. Where this feedback is going of this sensor. If in PLC you can use any sensor and can be progammed. IFM comapny must having these sensor .
Normally such sensor not failed every year.Failure can be by not proper installation, not proper position of installation, Input supply volatge vary to much, not proper grounding of the system and damage by human error
Regards
02/26/2009 12:42 AM
I had give this comment before also
Regards
S.Pathan
Register to Reply 10 comments
Anonymous Poster (3); Rksgolden (2); salim (2); Vulcan (3)
