Previous in Forum: Speed Sensor for Siemens 84.2   Next in Forum: Boiler Drum level Tx. Have Range in Negative
HART Pressure Transmitters
12/12/2008 1:50 AM
We are going to purchase a HART 4-20 mA pressure transmitter. Can I use this transmitter in the conventional 4-20mA current loop without using the HART functionality.
South Africa - Member -
Good Answers: 12
Re: HART Instrument
12/12/2008 2:03 AM
Hi there,
Yes you can. If you want to use the HART functionality - your input card would need this facility. The HART signal is only superimposed over the 4-20mA which is what you are interested in.
Just as a matter of interest, most trasmitters today come with HART already, but not many people use the actual functionality.
So in a nutshell - you can definately use the instrument as you would in a conventional 4-20mA loop.
Regards
Craig
Re: HART Pressure Transmitters
12/15/2008 3:50 AM
Yes you can, without anydoubt.
The Hart functionnality will remain there and you can access to them via a pocket.
The Hart signal is a digital protocol which is carried (as an FSK signal) over the 4-20mA signal.
Enjoy
12/19/2008 4:08 AM
Yes, as all the others above have indicated.
Check-out the Wikipedia page on the Hart Protocol for confirmation reading. It's a calibration/transmission system that is superimposed upon the 4-20mA analog loop without interference between them - that's the beauty of it. The transmitter will behave just like a non-Hart transmitter if the Hart stuff isn't in use. Come to think of it, it will do the same if the Hart stuff is in use as well.
Register to Reply 3 comments
Anonymous Poster (1); craigza (1); PWSlack (1)
