Previous in Forum: Battery   Next in Forum: GENERATOR INFORMATN
13 comments
redesigning electrical generator
12/13/2008 9:33 PM
self-propelled generator
Re: redesigning electrical generator
12/13/2008 10:47 PM
this self-excited generator's core is in vacuum tube in a vacuum tube , and magneticly balanced. it has an electromagnetic propultion ring on each end and several electricgeneration rings across it's tube. produceing more energy than it uses. i need someone to program the computer that will control the generator rings output base on eletrical usage.
Good Answers: 39
12/13/2008 11:09 PM
With or without dilithium crystals?
Maybe Scotty can help.
Elnav
12/13/2008 11:25 PM
scotty is no programer, and dilithium crystals don't have magnetic properties
12/14/2008 12:37 AM
I want to order a peperoni pizza.
12/14/2008 12:47 AM
free zza with every order
Good Answers: 54
12/14/2008 8:08 AM
scotty is no programer...
Yes he is, actually. Unfortunately, he's dead (God bless his soul) so you'll get no help from him.
Unfortunately for you, Vulcans respect the Prime Directive so I can't tell you anything.
Perhaps the Klingons? Ferengue?
12/14/2008 10:07 AM
Hello elnav:
No no no no, and HOW many times do I have to tell you, these devices require balonium , not dilithium. In case you've forgotten balonium is a infinitely strong , infinitely light, frictionless, superconducting material, although until now its existence had been hypothetical, and its primary use was in equations to eliminate variables and determine whether the end product was viable if the engineering problems could be overcome.
For example balonium was used to test the viability of Kip Thorne's time machine and the good news is we can build a time machine, provided we find a source of negative energy, and an infinitely strong material.
Considering the proliferation of over unity devices lately someone must have discovered a balonium mine.
If the original poster can demonstrate his device's ability to run perpetually without an energy source I will be glad to program it for electrical distribution. Unfortunately there is another substance that looks a lot like balonium, BULLIUM since I lack the necessary knowledge to program a device using this substance, I would recommend we provide free of charge for anyone using a device employing BULLIUM the excellent programming software XP antivirus 2008.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
12/14/2008 11:12 AM
it's not a perendev motor! it is more like an electric motor with six generators on the same rotor.well it's a little more complex than that ,but there it is. and please stop telling every about the mine and i'll cut u in.
Good Answers: 39
12/15/2008 1:52 AM
Hmmm! sounds like a triploid sextet rotivator.
Elnav
Good Answers: 247
12/15/2008 10:22 AM
Ordinarily, I would be inclined to agree, but I think, in this case, what has been so eloquently described is actually a linear diambuloid sextet rotivator. Although this may seem like semantic not picking, as you know, the linear diambuloid rendition of the sextet rotivator differs dramatically in Corier's coefficient at low rpm (from the triploid rendition). The tip-off, for me, was the mention of the duplexified vacuum tube. I don't have the Gernst-Hander article with me, but that article provided a clear path for the replacement of solid state devices (as used in the triploid) with vacuum tubes (as used in the linear diambuloid and the quadratic tripsoid).
All this could be a moot point, however, if the reflexive resonant tuning is incorrect. However, I gleaned from the original post, so slyly brief, that RED3 has his green machine properly tuned to turn oranges into purple grapes.
More details can be found here.
Good Answers: 39
12/15/2008 1:49 AM
Oh right! How could I forget? But the good news is there is a place that manufactures balonium in the presence of highly negatively energy fields. Its some place well to the south of where I am now, but the natives are quite vocal about it. They say its some kind of place with polarity. They keep referring to DC so I think that this must be the electrical field. And evidently the DC negative filed is where all the balonium originates. There isn't anything positive about it.
Elnav
12/15/2008 12:01 PM
The place you're referring to manufacturers BULLIUM, BULLIUM is created by subjecting BS to high temperature and negative energy field. The United States Congress creates millions of metric tons of BS and millions of cubic feet of hot air annually. The negative energy field currently surrounding Congress has yielded A BULLIUM bonanza.
However your accurate observation of the negative energy field was brilliant, I'm one step closer to building my time machine, and cornering the stock market. I'm only missing the infinitely strong material.
I've already found the location of the wormhole I need, it is located in New York at a place called Wall Street, we threw $700 billion at Wall Street and it disappeared from this reality, the wormhole is apparently a nonlocal event,as my wallet also sustained some losses.
Good Answers: 74
12/15/2008 5:47 PM
RED3
You must have noticed by now that your not going to get any where here. I have run out of Ignorium and have lost the program to get some more. It must have got stuck to some vacuum sealed magnet some where.
Could you not include a drawing of your device (or is it a contraption) so I could understand what you are proposing? It could be that you don't need to control the generator rings but the device/contraption it is running. Just let it run on full power all the time and use brakes to control it. The heat resulting from the friction could be used to make steam which could then power whatever.
I understand that your patent situation (if you want to patent it at all) is going to give you some more problems but not as many as you will have finding that programmer.
By some fluke my Ignorium generator has kicked back in and now leaves me with an amount that I could even share. True over unity. Please consider attaching a diagram. Just a hand drawing will do. I promise not to tell. Good luck finding that programmer.
The Twain Has Met
Register to Reply 13 comments
Anonymous Poster (1); Blink (1); elnav (3); ky (1); RED3 (4); Vulcan (1); YWROADRUNNER (2)
