Previous in Forum: Building a Wind-Power Generator   Next in Forum: Grin Lenses
33 comments
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Image Capture for a Wood-Fired Boiler
12/16/2008 5:18 PM
Hi! I'm looking for a simple and low-cost way of taking a look and to photograph the inside a wood-fired boiler firebox. The reason is to look at how the fire is acting, just where the fire is located inside the firebox, and see if airflows are correct. The firebox currently has one peephole but since one is looking past 18" of firebrick, the field of view is very limited.
However, there are ten, 4 inch air ducts leading into the firebox, and I was thinking if I could get some sort of long slender lens arrangment that could be slid down the air ducts, I could get a view of the fire from close to the inner wall of the firebox. Also, the lens arrangement could be wide angle so more could be seen from each viewing point.
The idea would be to do some viewing or photographing for a short period of time and withdraw the lens before things got too hot. Using the air ducts would help keep the lens relatively cool. (We have a lot of trouble keeping high temperature refractory surviving in this firebox.)
Are there devices of this type available on the market? Does anyone have any experience in doing this that they would care to share with me?
Thanks, Jon.
Good Answers: 39
Re: Low-cost optics to see or photgraph the inside of a firebox?
12/16/2008 8:38 PM
A long time ago the company I worked for at the time built a CCTV for Pilkinton Glass in Scarborough. The camera was permanently mounted inside the glass furnace to monitor the molten glass pour and our automatic controls adjusted the ladle pour to maintain a constant width of molted glass over the zinc bed. This camera was housed in a water cooled case and high quality quartz glass was usd for the front viewport.
With modern CCD products you should be able to do something similar and you could take advantage of modern technology to get a radiant IR filter coating on the front glass. Blocking the IR will reduce heat gain inside the camera case.
How big a diameter are the tubes you plan to use for visual acess?
Elnav
12/17/2008 10:43 AM
Elnav,
The tubes are 4". I was hoping to be able to use something about an inch in diameter so as not to make a big difference in airflow.
Jon.
Good Answers: 39
12/17/2008 11:32 AM
If you look at some of the latest CCD cameras they are only 1/4" diameter. Even with a 1" diameter water jacket pipe or hose you would still have plenty of room for air flow.
I have only seen plastic used for camera housing etc. Even some of the optical grade fibes seem to be plastic or at least optical glass with a plastic jacket around them. I remember we had a special quatz glass front cover to reflect radiant heat. Otherwise the amount of heat entering the front would quickly melt delicate components.
If you have a $50,000 or greater budget, the IR video imaging companies probably have something already on the shelf. Steel mills as well as glass mills would be using the camera technology we first developed back in the seventies. Otherwise you must make it yourself.
I recently saw a fiber-optic bore scope with a flexible tube. It was about 1" diameter. And it was plastic. But the good part was the price of $265.00 Now it becomes affordable to spend some money to provide it with cooling water jacket and heat blocking transparent front lens cover.
your description suuggest you would only be using it intermittently for part of a hour at a time. Possibly even less time. Begin by measuring the temperature inside the air tube in which you plan to take the observations. You might also test to see how fast a black body ( disk or ball) picks up heat when placed at the observation point. That will give you a good idea of how much heat you have to cope with in your cooling system.
Elnav
12/17/2008 12:14 PM
I was wondering about the possiblity of using a long glass rod, say, 48" long, with one end ground into a lens arrangement. It would be made of borosilicate or some other glass that can take the heat. A thermocouple could be attached to the side of the glass close to the front for a overheating warning.
The back end of the glass rod would be either polished flat or optically arranged so that a camera could be attached.
The idea would be to slide the arrangement into the firebox, quickly take a few photos and immediately withdraw. This would be through one of the existing air ducts, so we would have the advantage of the flow of cooling air.
My knowlege of optics is not so good, so thats what is causing my head scratching over what is possible and what is not.
Your comment about a commercially available borescope is a good one--I was just looking at a Milwaukee version at the local Home Depot. They seem to be a little short on the length of the snout (for our particular use--we'd need about another 2 feet) but the basic tool is there. Maybe it could be enclosed in a jacket with some forced air cooling to get our job done.
Jon.
Good Answers: 39
12/17/2008 12:37 PM
If you have access to borosilicate glass rods and the required grinding machinery - try it. I think the bore scope I saw was also the Milwaukee - but not a home Depot. Check and see what result you get with a short glass rod with the ends polished flat.
Incidentally, most companies that use fiber optics for communications have the required polishing equipment. I once had to install a fiber link from our office to the shop building. Not knowing the procedure I hired at considerable cost a "specialist" to come and prepare the optic cable ends .
Afterwards I realized they used the same materials and procedures as is used to polish telescope mirrors or removal of scratches from aircraft windshields.
Fiber optics rely on a perfectly flat face perpendicular to the long axis of the cable.
My buddy at Bell was trained to repair splice fiber optics but they used a nematic fluid to effect the efficient coupling of light beams into the broken ends of a fiber cable. Maybe you can use a similar technique between the glass rod and the bore scope.
The Bore scope I saw also had fish eye lens arrangement. If that is preferred, maybe you could detach the fisheye lens and place it at the forward end of the glass rod and the camera at the back end.
Use the nematic fluid to give you a reflection free optical coupling.
Elnav
Good Answers: 94
12/18/2008 4:39 AM
You could use a hard fibre optic rod, if a lens at the 'hot' end produced an image on one end of the fibre optic that image would be reproduced at the other end. We use these types of optics in vacuum tubes & seal them to metal components using pyroceramic, these are fired at 450°C without harming the optics.
Talk to either Schott or Incom in the USA.
Good Answers: 11
12/18/2008 7:49 AM
Fiber optic is the way to go. Just get a boroscope or endoscope - can probably find either on the surplus medical market. Get an adapter for a digital camera, hook it up to a LAN and you are all set.
Eric
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
12/18/2008 3:31 AM
CCD cameras they are only 1/4" diameter??
Please pray tell, where can I buy those??
Donald
Check out our home page for specs on "Soft Neon"
Good Answers: 39
12/18/2008 12:41 PM
Most new laptops come with them built into the screen frame. Have a look at the ones built into new cell phones.
I also see them for sale in the local flea market. One bigger model has a ring of LED lights around the central core and that housing is almost 1" in diameter. We did a televised commercial and the camera guy hid several 1/4" diameter CCD that wer abour 1/4" diameter. He tucked them into the air grille in the dash.
Elnav
Good Answers: 15
Re: Image Capture for a Wood-Fired Boiler
12/18/2008 12:37 AM
Every industry has most likely today done something on video and I suspect something in fire has been done too. I was at one time in the Pest control business and at a convention a salesman showed me a fiberoptic camera and the optic cable was what was inserted to view back at the suit case reader. Seems like, back 10 years ago ,they were too much for me perhaps, $25,000. He told me if the fiber optic was damaged it was cheap to replace so you might could keep sticking new ones, in the hole to view with inexpensively.
Why not check with a fire departments, head investigator. They have access to all sorts of fire investigation equipment and the time to read about what they don't have yet. Also, other boiler makers may have explored this. Perhaps, a trade publications editor, would have a line on the equipment and or a reference.
Hope That Helps Some.
Best Regards,
Joe Woodall, Managing Partner
Georgia Adobe Rammed Earth & Renewable Energy
Dewy Rose, GA 30634
http://www.georgiaadobe.com
Join Our Yahoo Forums To Learn More At :
http://finance.groups.yahoo.com/group/georgiaadobeforums/
12/18/2008 4:18 AM
You could also contact a IR camera manufacturer and explain your application. They will certainly have solutions to propose you.
Flir Systems : http://www.flir.com/thermography/eurasia/en/
Good Answers: 19
12/18/2008 8:08 AM
I've seen cameras inside cylinders of diesel engines for research of flame front, so I know super special cameras exist. I have no clue where to buy them. I've put in a question to head of a laboratory for a major diesel engine supplier to find out for you.
Good luck
Good Answers: 94
12/18/2008 8:23 AM
Like this video? Click on the R.H. image, 2nd row down.
We supply the detectors for their cameras but you would need to save up for a long time to buy one.
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
12/18/2008 8:38 AM
You could do as Sam McGee and just crawl right in and have a look.
I am very interested in what you are working on. I worked designing and developing wood burning furnaces some years ago and still tinker at a hobby level. I built my own furnace a few years ago and I am considering buiding a new one to try out a few ideas.
Email me if your interested in corresponding on this topic.
ref: The Cremation of Sam McGee by Robert W. Service
-why bother doing it wrong when it will be anyway.......
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
12/18/2008 11:10 AM
Come to think of it can you recommend me something good on this issue?
Making mistake is part of learning.
12/18/2008 11:53 AM
Hello, all:
I have emailed Schott and Incom, although the guys that specialize in the defense and medical fields never seem to know the meaning of "low cost"...
Since I posted this question, I have also sent questions to several outfits who fell out of Google searches for "high temperature borescopes". I have found I can rent video equipment made for imaging in boilers for costs on the order of a couple of thousand $ per week. So far that's my only option, but the search isn't over yet.
The suggestion to chase down used medical endoscopes or borescopes is the best one yet for "low cost". Might have to steam clean the lumps off if the endoscope was last used for the wrong "end-o". (Sorry, couldn't resist)
gdevine, I am interested in talking to anyone with woodwaste combustion experience. The boiler in question is an old Dutch Oven and it is costing us tons of money per year in firebox refractory repairs plus pretty high particulate levels. It is 38 years old and certainly needs a dose of modern technology. We have lots of bells and whistles on it now- O2 analyser, PLC control, FD and ID fans with variable speeds, firebox pressure sensing and control loops to keep a negative pressure in the firebox. But the airflow and firebox shape are still yet to be massaged with some decent knowlege, thus the foray into trying to get an idea of what is happening in the firebox. By the way, I don't think I mentioned it is burning dry planer shavings--real good, hot fuel.
Thanks,
Jon.
Good Answers: 39
12/18/2008 12:58 PM
REPLY: Don't you produce enough waste wood to justify converting the scrap to wood pellets. Or are you running a co-generation power station.
Dunkley just down the road from us is now pelletizing all their waste wood. My neighbor runs the planer mill so they must have plenty of shavings as well as saw blade dust. Their old beehive burner was used to handle all the waste, but will be shut down end of this month. All this wood waste now goes to the new pellet mill built last summer . They found it more profitable to supply the pellet plant than to keep the bee hive going.
Or if not pellets how about hog fuel? There are three major trucking companies that transport wood chips from here down to the coast 750 kilometers away. A tandem trailer train goes thru the village every ten minutes round the clock.There the chips are loaded on a barge and shipped over to Vancouver Island to the power plant there. Once the cellulotic digester is built, they won't leave a single chip of waste wood on the ground after the loggers are done.
Elnav
Good Answers: 204
12/18/2008 1:51 PM
Think outside the box.. :) pinhole camera. so that the components won't be melted, and the cost is much lower.
chris
Good Answers: 39
12/18/2008 2:21 PM
Trouble with pinhole camera is the distance from pinhole to focal plane. In this case a 4" diameter tube approximately 24" long will mean the visible area is much too small.
The tube diameter wil act as a blinker. Try it and see what I mean. To get a good view inside the fire box requires a fish eye type wide angle and for that you need a lens, not a pinhole.
Elnav
12/18/2008 2:31 PM
Chris,
Yes, thats how the big boys make the commercial units, so it is doable. I think it's pressurized with air as well, so there is a jet of air coming out of the pinhole keeping the opening clear and the whole thing cooled.
As elnav points out, the focal plane needs to be fairly close to the pinhole, to achieve the wide angle viewing desired, so the CCD will have to be closer to the action than one might hope for.
Jon.
Good Answers: 39
12/18/2008 3:48 PM
Sawmilleng how much air pressure or air flow do you think you would get. I assume you are talking about inflow of fresh air to the combustion chamber.
Elnav
12/18/2008 5:00 PM
Elnav,
I'm just talking about cooling the pinhole camera--the big guys use both air and water cooling. Nothing to do with the combustion air, although the tiny amount coming thru the pinhole ultimately adds to the combustion.
It would be my guess that they would use compressed air, so the pressures could be high enough to get enough air mass through the viewing device to balance the BTU's coming in through heating. Might be quite a bit, unless they used water cooling as well.
Just guessing here, as I have no detailed knowlege of how the commercial ones work, other than some brief looks at web pages over the last couple of days. Didn't look very long 'cause I couldn't afford them.
Jon.
12/18/2008 1:52 PM
A little off but I would like to know where I can get the wood-fired or coal fired boiler for small residential or work-shop use ( not the large greenhouse ones) this would hook up to hot water heat system
Good Answers: 39
12/18/2008 2:24 PM
Woodmaster has a small model that is good for up to 4000 square feet area. We sell a lot of them for 1200 - 2000 square foot homes with adjacent shops of 2000 - 3000 square foot area.
Check out Woodmaster model 4400.
Elnav
Good Answers: 94
12/19/2008 4:16 AM
Good Answers: 12
12/18/2008 3:20 PM
For a very inexpensive method, you could use a series of small mirrors.
I recall a documentary about the pyramids. It suggested they used a series of mirrors to light the work inside the tunnels.
Good Answers: 204
12/18/2008 3:48 PM
don't believe everything an egyptologist tells you.. What are the chances that someone can build the largest construction every undertaken on earth (at the time), producing better-than-optical precision, and encoding within it almost all known mathematics and sciences.. and not know how to produce artificial lighting. The object itself is a power plant, and the grand gallery may well be a giant tuned laser chamber... It was all built with precision and technology that I seriously doubt we could reproduce it, in its Original functionality. there are clay tablets that report it had 3 functions.. basic communication with air/space craft, defense from the same, and inter-solarsystem communications (within our solar system)
Occam's razor eliminates the traditional egyptological theories, because they are insufficient to explain the features evident. period.
Chris
Good Answers: 39
12/18/2008 4:16 PM
Of course it wasn't just mirrors. It was a sophisticated solar energy collector that directed the sunlight into the interior for power. Just like the spanish solar oven. And the technology came from Alien visitors to Earth.
Elnav
Good Answers: 204
12/18/2008 4:32 PM
I'm sure Del The Cat travelled back in time and showed them how to do it.
which is why it is still beyond us.
Good Answers: 204
12/19/2008 12:46 PM
Perhaps you could simulate the turbulence and expanding gas flow using cooler mediums like water and injecting gas bubbles under pressure into a water filled and flowing chamber... ?
chris
Good Answers: 204
12/19/2008 1:22 PM
or a water cooled hollow window?
12/19/2008 1:23 PM
Chris,
Boy, you really specialize in thinking outside of the box! Good on you! I'll bet your employer has to run after you some times with a butterfly net to get you back into a more boring reality that mere mortals can understand!
I expect modelling a of firebox has been done, but I'm guessing that it is in the realm of the big boys and in a computer modelling environment. It would be darned interesting, tho, to see how close to reality it could get.
I have located a low temperature borescope, 38" long x 8 mm diameter, good for about 200F, for $3,000. It has a screwed adapter that will adapt to a 37mm camera filter lens threads.
I can get it custom made with a wide angle lens on the end to do 90 degrees or better at a slightly higher price. Doesn't sound too bad but will have to give it some thought about a gas cooling shroud and a temperature sensor to warn that it is getting too hot.
It's still a lot more than I would be comfortable to pay. Still hoping to find someone who can explain the optics necessary to see if I could build my own for a tenth of what I would have to buy a commercial one for.
Jon.
Good Answers: 204
12/19/2008 1:44 PM
thanks for the compliment... I remember our wood stove with the layers of mica for looking through.. about 2" square, as a boy.. and being fascinated watching the fire.
you know a Mig welder has a outward flow of gas (nitrogen, argon?) surrounding an inner core. I wonder if such an arrangement wouldn't also keep your borescope cool enough if it was contained within a heat resistant material(s).. with ceramic insulators.. I know there are sleeves you can get for fire-guarding hydraulic hose..
chris
Register to Reply 33 comments
Anonymous Poster (1); ca1ic0cat (1); Campbell Lighting (1); chrisg288 (6); elnav (9); gdevine (2); Georgia Adobe (1); Isti80 (1); MSsteel1 (1); Nigh (3); PetroPower (1); sawmilleng (6)
You might be interested in: Lens Holders, Wiring Ducts, Fire Suppression Systems
