Previous in Forum: Distribution Transformers   Next in Forum: electrical engineering,star delta starter
18 comments
Best Way to Locate a Break Underground
12/29/2008 8:35 AM
What is the best way to locate a break in an underground electrical PVC conduit without digging up the total length?
User-tagged by 1 user
Good Answers: 27
Re: Locate break in underground conduit
12/29/2008 9:02 AM
What kind of electrical cable is inside the conduit and, how do you know the conduit is broken?
It's likely that the conduit was used to facilitate installation and cable replacement in the event it is ever necessary (as opposed to direct burial).
If you really do need to locate a break and the conduit end is accessible, a cabled camera or illuminated boroscope would probably be the best way (assuming there is adequate clearance between the cable and conduit).
Given accessibility to the conduit end and the ability to couple the transducer to the wall, an ultrasonic test might also be possible. A break would certainly reflect the ultrasonic wave and by scanning around the wall circumference, the characteristics and location relative to the sending end could be determined.
Good Answers: 266
Re: Best Way to Locate a Break Underground
12/29/2008 10:49 AM
Cable fault locator. Google it many to choose from.
12/29/2008 10:45 PM
Git ya a twig. holt not too tight to tha ends. Now go to pacin about through the yard back and aforth til that ol twig gits ta twitchin and jumpin around. Banjo!- thar it is. Right whar the twig a tol ya it would be.
01/06/2009 10:26 AM
Pack it in, Del.
12/29/2008 10:49 PM
If you have a break in the conductor the fault trace is the way to go. If you are trying to locate a leak in the pvc conduit itself your best bet may be to pressurize it with air and use a listening device to locate the escaping air.
Good Answers: 68
12/30/2008 2:00 AM
Hello prahlcon@bellsouth.net:
What size conduit are you talking about? And is it just one cable , power, telephone? How deep and is it under concrete anywhere along what you know of its route?
What makes you think the conduit is broken anyway? Have you found water in a junction box?
If there is a junction box one the outside and the inside of the building wall, is it possible to disconnect the bit of cable either side and pull the cable out. And renew the suspected damaged conduit with new iron conduit where it goes below ground? Here in the UK our gas and electrical conduits, and water pipes can be replaced by pulling the old piece out and using air to push a new bit through the ready made hole. If the hole is the wrong shape compared to the new conduit the air is powerful enough to push the pipe etc through any soil, but clay is ideal.
Good luck and have a great new year.............
12/30/2008 8:15 AM
Find the access panel doors and take a look!! Oh, the conduit isn't in a concrete encasement channel? Well, in the future, instead of deep-trenching and placing naked electrical conduit all over here and there, follow the Plumbers lead in placing manholes every so many feet!!
Running an encasement channel under street and roadway sidewalks, medians, peninsulas, and/or shoulders leads to all kinds of better, safer, and easier maintenance and replacement, modifying and uprading, and adding new/more electrical, communications, and cabletv lines and conduits!!
Shorter distances of trenched lines from the street to the buildings, easy access for street lights, signs, transfer stations, etc; and an in-place anchorage for bike racks, sign poles, bus/train stop benches, and so on are just some of the advantages of multi-use continuous concrete encasement channels!! A very smart power and energy grid concept!!
Another bonus is the weather-tight and flood-proof access doors/panels at every 16-20 feet along the channel for maintenance, and in high wind/seismic regions, eyebolt holddowns can be added at each access door/panel for emergency strap tie-downs for cars, trucks, bicycles, etc!!
You can find some samples of multi-use encasement channels at website: Tor-Eggs-Tor Design Solutions, or at the link: http://www.dubephnx@tor-eggs-torclosed-nets.org. (Try the search engine type-in if the link is not getting you to the site. Another CR4 Blogger said he had to direct-type to the website.)
Hope this helps; Happy New years, Randy
12/30/2008 10:54 AM
Shameless self-promotion without addressing the question.
12/30/2008 1:38 PM
Self-Promotion? You benefit more than me, you make more money per linear foot than me, you don't have to blindly search for the deep-trenched powerline, you don't have to "shamelessly" overcharge your Customers, the Public, etc.
The Questioner asked what is the BEST way to locate a break underground. The systems I am illustrating are new, so how else do I show what appears to be the BEST way to locate an underground break? He asked a straight forward question, I gave him a straight forward on topic answer.
I have over 40 years of Construction experience, and am well aware of the ongoing problems in laying deep-trenched power and energy lines. They eat up most of any Construction Project's Profits, are hard to maintain, replace, repair. They are extremely dangerous in earthquakes.
Just because an idea/concept is new, doesn't mean the Author is self-promoting. As a matter of fact, the Author might even be lending a hand to his Fellow Construction Veterans, etc.
God Bless and Speed; RLD.
01/06/2009 4:57 PM
"The Questioner asked what is the BEST way to locate a break underground."
Please re-read the original post. The question is "What is the best way to locate a break in an underground electrical PVC conduit without digging up the total length?" (emphasis mine)
While the system you discuss may save him significant time & money on a new project, your reply has absolutely nothing to offer the Poster regarding his problem with an existing installation, ergo:
01/01/2009 10:06 AM
Update: Fault Tracers, Oscillators, and TDR's all work for power lines that are deep-trenched, encased behind/within building walls, and encased within concrete multi-use encasement channels, FYI. All of these locations are currently in use to house electrical wiring, conduit, and cables, along with overhead power lines. Encasement channels are the rarest, today, but hopefully will be the "Smart Grid" of tommorrow!!
Good Answers: 150
12/30/2008 9:17 AM
Clarify please, are you looking for the break in the conduit or the conductors?
if it is the conductors, you need to use a TDR (Time Domain Reflectometer). It is essentially a simplified radar set. it sends out frequency swept squarewave pulses along the conductor. Breaks and damaged insulation change the inherent impedance of the conductor and reflect back part of the ougoing signal. The TDR then calculates how far away the break is based on the speed of light in copper. There are some relatively cheap and simple ones sold for telecom/network use.
Here is another
And another
Who is John Galt?
12/30/2008 8:19 PM
Regards.
Conductor break or leakage, short-circuit & other defects are detected from remote with TDR [Time domain Reflectrometery] Equipment.
All the organisations use it. It will show distance @ which fault is & type of fault like as said above
Kind regards
By chance below you can have a more details
You might be interested in: Time Domain Reflectometers,
01/01/2009 7:07 AM
An oscilloscope can be configured for use as a TDR, but you must know the characteristics of the cable involved for reference.I know it works on coaxial and shielded cable,but have never tried it on standard non-shielded electrical wiring.I do not think they control the capacitance and inductance of power wires very closely,because it is not necessary. If you need further info on configuring the scope, let me know, and I will dig out my old notes on this-----------------------------------------------------------------------------------HTRN------------------------------------------------------------
01/01/2009 10:13 AM
The old-fashioned way to locate where a PVC conduit break is, is to find one end of the conduit, pull on it gently and with enough force to slide the conduit out of it's bedding, and measure how far the pulled out conduit is. The break is that distance in from the end of the conduit.
Randy, the "eggster" Dube!!
01/01/2009 10:49 AM
Uhh. Come again?
01/01/2009 11:00 AM
What's the matter, Charley, a Construction Industry Old-Time Traditionalist/Veteran didn't fall for one of "them-there" "gotcha" question?!! I couldn't resist!!
God Bless and Speed; Randy.
01/06/2009 10:26 AM
Push a rod-shaped instrument into the end of the conduit and see where it meets mechanical resistance.
Register to Reply 18 comments
Anonymous Poster (5); babybear (1); Bluestone (1); dubephnx (5); Haajee (1); ozzb (1); PWSlack (2); Rorschach (1); TexasCharley (1)
