Hi all,
I am trying to work out what the maximum force (torque) that a stainless steel/alloy pipe can withstand before deforming or breaking.
Does anyone know the formulas to do this?
The pipe is a part of a wrench (the handle) and so I have been treating it as a cantilever, as if the bolt hand ceased turning but applied force is still being applied.
The problem I keep getting is that the results seem incorrect and I have nothing to compare it too.
The pipe is 180 mm long with an internal radius of 2.5 mm and an outer radius of 7.5 mm making the pipe 5 mm thick.
The elastic modulus of stainless steel is 195 Gpa and the shear modulus is 77.2 Mpa.
The applied force being 41.8 N/m.
My result using these figures is -23032656 N/m and this appears high!
Thank you for any light you can shed on this issue.
Samurai 7
