Previous in Forum: piping miters   Next in Forum: Minimum Design Metal Temperature (MDMT)
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Safety & Relief Valve
02/04/2009 3:56 AM
Anyone please tell me what is the difference between a Pressure Safety Valve and a Pressure Relief Valve ?
Also please elobrate on Pressure Control Valve. Is it same as to Pressure Relief Valve ?
Sanjay Vadhaiya I BecRel Engg. Pvt. Ltd. I Reliance Industries I Navi Mumbai-400701
Re: Safety & Relief Valve
02/04/2009 4:09 AM
There is no real difference in the first two terms. They both limit the pressure upstream of the valve.
The third maintains a set pressure downstream of the valve. So it's not the same thing as the first two.
Good Answers: 103
02/04/2009 4:33 AM
please check a thread a few days back on exactly the same subject from your company, from your city.
Neither you google and it is obvious you do not discuss with your colleagues before running to computer and posting on forums.
Don't you share amongst yourselves or you find this forum only for time killing purpose.
I don't know the circumstances but i sincerely feel this type of environment do not signify a good organisational culture.
I am blunt, but I hope you will understand and try to improve the culture around you. Be a change agent.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
02/04/2009 4:18 PM
Choose this link. The same question was just asked the other day.
Location: Johannesburg South Africa in a quiet Garden Suburb of Edenvale
02/09/2009 11:57 PM
Hi Sanjay:
I don't see any reason why someone could not start a new thread on a subject which has been mentioned before - after all we don't all follow forum discussions all the time and could easily miss some where they could have made some good contributions.
Pressure safety valves and Pressure relief valve are essentially the same type of valve. A Safety Valve has a connotation that it is used more where an overpressure could cause serious harm and damage, such as in Steam Safety valves on Boilers. A relief valve can be used in low pressure water systems where it is convenient to ensure that pressure does not exceed a setting as it causes some discomfort or minor damage to equipment. A Safety relief valve also opens fully when setpoint is reached whereas some relief valves (other terminology is a Pressure Sustaining Valve), modulate and only open far enough to maintain the setpoint at its desired setting.
A Pressure Control valve is a general terminology for a valve which controls pressure ie either upstream of the valve (Pressure Relief valve) or downstream of the valve (Pressure Reducing valve).
I trust this casts some more light on the subject
A passion for Life, Family, Valves, Pipelines and Hydraulics
12/06/2012 4:35 AM
Dear SANJAY VAIDHYA
The difference between SAFETY VALVE and RELIEF VALVE
Relief valve will shut as soon as the working pressure is reached, since it works on lever principle since the MOMENTS of working pressure and the pressure due to dead weight is balanced.
SAFETY VALVE, will vent out as soon as the set pressure is reached but will shut down well below the working pressure which will be less than the SET PRESSURE to the tune of 0.5% to 1.2 % some times even 2.0% to 2.75% and this margin of difference between the set pressure and closing pressure is known as BLOW DOWN of the SAFETY VALVE.
Further Relief Valve is referred for the fluid flow system and incompressible fluid flow system
Also refer the link in CR4
http://cr4.globalspec.com/thread/32517/Pressue-Safety-Valves-vs-Pressure-Relief-Valves.
Thanks,
DHAYANANDHAN.S,
dhayanandhan (1); Peter Telle (1); PWSlack (1); sb (1); Steve Melito (1)
