Previous in Forum: Ball Valve Sliding Stem   Next in Forum: On Off Valves
DP Transmitter Range and Orifice Diameter
02/10/2009 11:42 AM
i have some data of process. i want to install dp transmitter.
how i find the dp range and orifice dia. any formula.
my data is :
line size : 100mm
pressure : 3 kg/cm2
flow : not perfect but appx. 60m3/hr.
want to install dp transmitter how i get dp range and orifice dia details.
thanks
hites
Re: DP Transmitter Range and Orifice Diameter
02/11/2009 5:07 AM
Hites,
The basic equation for Orifice mass flow calculation is
q=CEY(pi/4)d²*Square root of(2groDP)
Where
unit system is imperial
Q is mass flowrate in lbm/s
C : discharge coefficient (no units)
d : plate bore diameter (feet) @ flowing temperature (T)
DP : differential pressure (lbf/in²)
E : velocity of approach factor (no units)
g : dimensional conversion constant (lbm-ft/lbf-sec²)
pi : universal constant (3.14159
ro : density of the fluid and flowing conditions (P and T) (lbm/ft3)
Y : Expansion factor (no units)
This is extracted from public documentation.
Based on this, the information you provide are not sufficient.
You need to specify : P, T, density at flowing P and T, type of fluid.
Please note orifice plate bore calculation is carried by iteration normally. In other words, you do several iterative calculations before reaching your final results.
You can access to detailed calculation method by purchasing suitable calculation softwares or the standards (ISO5167 or AGA3) which provide you with the equations.
enjoy
02/11/2009 10:27 AM
sir i want to use it for water at normal temp appx. 25degree c.
thanks
hitesh
02/11/2009 10:51 AM
You need to carry the calculation.
Alternatively, the supplier of the transmitter should be in a position to carry the calculation for you.
03/02/2009 11:02 AM
Consider electromagnetic flowmeters instead, which can be more attractive at these line sizes.
03/04/2009 3:24 PM
Use the link to get the calculated value:
http://www.flowmeterdirectory.com/flowmeter_orifice_calc.html
hiteshpurani (1); jm (1); PWSlack (1); Reivax (2)
You might be interested in: Radio Transmitter ICs, Steam Traps, Rheometers
