Previous in Forum: Mini-DIN 8-Pin Connectors   Next in Forum: Hardness testing of plated/coated parts
transfer from autocad to 3D Max 5
02/11/2009 5:52 PM
how can i use an autocad file in the 3D-Max 5 programme ?
Pathfinder Tags: 3D Max 5
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: transfer from autocad to 3D Max 5
02/11/2009 6:17 PM
I know it can be done, because I have created 3D models in Mechanical Desktop that a colleague used to make a make a flyaround in 3DS Max. MDT is a program that sits on top of AutoCAD Mechanical, and it saves files in the .dwg format.
I'm not sure how to bring in the .dwg files. Probably go to File > Import.
You might also post this question in the AUGI forums or the Autodesk Discussion Groups.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
02/11/2009 8:44 PM
yes of cause.
you can use import to do so.
Good Answers: 19
02/12/2009 7:05 AM
CNPOWER . good to see you. Long time.
Register to Reply 3 comments
3Doug (1); cnpower (1); ducon (1)
