Previous in Forum: Three phase electrical machines with no return   Next in Forum: Unity Power Factor
8 comments
Safety - ESD - Inspect all things, keep the good things safe! New Zealand - Member - PalmerstonNorth -hub of the Manawatu.
Electrical Switchgear Ratings
03/04/2009 8:04 PM
What is the difference between AC 21, AC 22 and AC 23 ratings when looking at contactors and switchgear coming from Germany?
Any help is appreciated.
Jakbeuk
Observe-Plan-Execute-Monitor-Control
Re: Electrical switchgear ratings
03/04/2009 11:57 PM
Check out http://support.automationdirect.com/docs/capacitychart_a.pdf
to start, this is a basic explanation. If you need more info, you will need to look deeper into IEC low voltage switchgear.
"Real Bass Players" do not use picks
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
03/06/2009 4:21 AM
Hi, Jimh77!
Bingo. GA.
Mark
03/17/2009 12:35 AM
Thanks for your help, its excellent!
Re: Electrical Switchgear Ratings
03/06/2009 12:50 AM
AC ratings are utilisation factors. AC 2 is slip-ring motor contactor. Subsequent numbers relate as 1 to PF, 2 min time etc Refer to AS/NZ 60947 or therabouts Thhis is acopy of the IEC standards
03/11/2009 1:50 AM
my friends , could you introduce some MV switchgear manufacturer to me ?
03/11/2009 2:05 AM
Siemens and Allen Bradley, GE and Square D are the ones I've worked on.
03/11/2009 2:24 AM
i am sorry to you are misunderstand me ,i need some MV switchgear manufacturer location in indian ,hehe ,thanks
03/11/2009 2:42 AM
Not a problem,
All of these companies are world wide. Everything is Global now. Actually AB has been for about 30 years or more, Siemens I believe is rooted in Germany, I could be wrong on that though. GE is local, but Global and Schneider took over Sq D several years ago which are also Global. I am sure there are others, The ones I named are the units I have worked on and or sold when I was an AB distributor.
Register to Reply 8 comments
jakbeuk (1); Jimh77 (3); MarkTheHandyman (1); ronhu (2); skippyaust (1)
