Previous in Forum: Generator Load Sharing   Next in Forum: Motor Installed Power vs. Power Input
Power Transistor Schematic
03/11/2009 9:18 AM
I have a GE VCR Model VG 4054. There is a power transistor that gets very hot. Like to find a schematic for it, that dosen't cost more then the VCR. Have no idea where to look. Markings on the transistor has a K above C4419. Can't find any parameters for it. Any info from someone would be greatly appreciated.
Thanks,Greenturtle
Pathfinder Tags: Trouble shooting
Re: Circuit board trouble shooting
03/11/2009 10:59 AM
This what you're looking for? http://doc.chipfind.ru/kec/ktc4419.htm
Afterism (n) - A concise, clever statement you don't think of until too late.
03/11/2009 1:38 PM
Thank you so much. It will give me a lot to work with. Had the transistor out of ckt, didn't know what to replace it with. It seems to check O.K on a continuity check. I'm not that sharp to figure out if the transistor is bad, causing a large current drain or some component in the circuit. It's hard to check things while in circuit, almost not possible for any true readings. I sure appreciate you finding that for me. A schematic would help a lot. Can't find one of them either. But now I can at least sub the transistor. Thanks again.
Register to Reply 2 comments
You might be interested in: Pushbutton Switches, DC to AC Converter Chips
