Previous in Forum: Please Help Me Find Cellular Amplified Antenna Plans   Next in Forum: RF Shielded Enclosure Question
Looking for Battery impedance sensor
11/10/2006 1:07 AM
Hi all,
I`m looking for battery impedance sensor to measure impedance of Valve Regulated Lead Acid battery or Flooded Lead Acid.This sensor will be used as an input for my data logger.
The specification is : range measurement from 0-300 miliohm,sensor output 0-5 V,can be used for application voltage 2-240 VDC.
Please give me some reference....
Regards,
Imam Yulianto - Jakarta,Indonesia
Re: Looking for Battery impedance sensor
11/10/2006 9:07 AM
11/12/2006 1:28 PM
The normal way to measure battery impedance is to superimpose a very small ac low frequency signal on to the battery terminals and measure its attenuation, knowing its source impedance, open circuit level and amplifying the output to give the impedance.
John.
Register to Reply 2 comments
You might be interested in: Battery Holders, Impedance Matching Networks
