Previous in Forum: Transformers - Calculating the HT Fault Level   Next in Forum: Circuit Breakers - Comparing MCCBs to ACBs
DG set calculation
03/13/2009 1:40 AM
can any one tell me the design of DG Set of 750KVA with 415 v
Re: DG set calculation
03/13/2009 4:01 AM
Your question is??????
03/13/2009 5:39 AM
my question was ,what are the design consideration of DG set of 750 kva for 415v ??????
03/13/2009 4:26 AM
Yes. Loads of people. They can be spoken to on the telephone.
03/13/2009 10:25 AM
Either you want to design consideration for manufacuring of 750 KVA DG set or not.We are not clearly understanding.
Good Answers: 19
03/15/2009 8:28 AM
Do you want to design a 750 kVA dg set for manufacture
or do you want to select the dg set for an installation?
Your query is not clear for us to understand,more clarity is required .
Ramesh,Freelance Electrical/automation Consultant
03/16/2009 2:02 AM
for Installation
03/17/2009 6:50 AM
Type of load, Running load, starting of major load, voltage drop, duty class, etc. DG set rating selection is an important calculation one must do before recommend. Try on your own.
BNDas
Register to Reply 7 comments
Anonymous Poster (1); biswanath.das (1); fakruddin (2); lavurk (1); PWSlack (1); ramvinod (1)
