Previous in Forum: conservator, desiccant   Next in Forum: Electrical Shock - Current and Voltage
mccb
03/16/2009 5:07 AM
hi all
i am using a 100 A mccb but requirment of 32A Mcb can any one tell me what will be it drawback
Good Answers: 804
Re: mccb
03/16/2009 5:33 AM
When your load current reaches 33A, whatever the 32A MCB was supposed to protect will begin to overheat, eventually catching on fire probably long before the 100A MCCB will trip.
Re: mccb
03/16/2009 5:42 AM
cant understand
i want to know can i use 100A mccb instead of 32A although i know load current is not more than 25A
Good Answers: 19
Re: mccb
03/16/2009 5:46 AM
You can use 100 A MCCB but this will not protect your devices for over load beyond 25 A.This MCCB will have normal thermal settings 0f 80-100%.Therefore for any current beyond 80 amps only this MCCB will trip and isolate the circuit.
Ramesh,Freelance Electrical/automation Consultant
Re: mccb
03/16/2009 6:29 AM
what will happen at time of short circuit . as i know current will be very large at time of short ckt
Re: mccb
03/16/2009 6:37 AM
Either the 25A device, or the cable feeding it (whichever has the lower rating), will go BANG!
Last out the building is a cissy...
Re: mccb
03/16/2009 9:19 AM
You will then have the opportunity to design and install a proper circuit, assuming the building is still there.
Re: mccb
03/16/2009 6:34 PM
Actually, a short circuit might well trip the 100A MCCB, but there will be no protection from overloading and burning up the 25A load. CJM
I do not 'know it all', but i will admit that I would like to. CJM
Register to Reply 7 comments
CJMcGill (1); dineshpandit80 (2); JRaef (1); lyn (1); PWSlack (1); ramvinod (1)
