Previous in Forum: New Hobby User Group - Automotive Performance   Next in Forum: Audio Engineering.
Wt of MS Angle
03/26/2009 10:51 AM
What is weight of ISA 90x60x8mm?
Good Answers: 103
Re: Wt of MS Angle
03/26/2009 1:55 PM
Calculate the volume =
Multiply by density
Get the weight
Re: Wt of MS Angle
03/27/2009 4:03 AM
One of the ways of working it out is to do a "rubbing":
  • take a sheet of squared paper and a pencil
  • hold the paper firmly over the end of the steel
  • rub gently with the pencil, until an impression of the steel is left on the paper
  • count the squares blacked in
  • calculate the cross-sectional area
  • measure the length
  • obtain the volume
  • divide by the density of steel
"Robert is your mother's brother".
Good Answers: 19
Re: Wt of MS Angle
03/28/2009 1:44 AM
1.5" X 1.5" X 1/4" - 1.05 KG/FT
2" X 2" X 1/4" - 1.44 KG/FT
2.5" X 2.5" X 1/4" - 1.83 KG/FT
3" X 3" X 1/4" - 2.22 KG/FT
3" X 3" X 3/8" - 3.25 KG/FT
4" X 4" X 5/16" - 3.85 KG/FT
4" X 4" X 3/8" - 4.41 KG/FT
4" X 4" X 1/2" - 5.78 KG/FT
Good Answers: 103
Re: Wt of MS Angle
03/28/2009 3:18 AM
This procedure is strictly not acceptable by our Quality management System .
You talk in imperial system
1.5" X 1.5" X 1/4" - 2.31 lbs/FT
or in SI (or modified SI - mm and Kg)
38.1 x 38.1 x 6.35 = 3.44 Kgs/m
Good Answers: 19
Re: Wt of MS Angle
03/28/2009 4:50 AM
The weights given are in Kgs/ft not lbs/ft.
Convert it to read :
40mm x 40mm x 8mm - or
50mm x 50mm x 8mm
This procedure is strictly not acceptable by our Quality management System.
Dosen't matter as long as you have an idea to estimate the total weight/length you require with +/- 99% accuracy. To me thats good enough for me.
ducon (2); PWSlack (1); sb (2)
You might be interested in: VU Meters, Polarizing Cube Beamsplitters, Backplanes
