Previous in Forum: The HHO Test Plan   Next in Forum: Leak Testing
35 comments
INHIBITING RUSTING OF A CAR BODY
03/28/2009 3:31 AM
Hello Everyone,
I now live in Malta some 60 metres from the sea and have a car with a GB plate and a garage. The car is 13 years old and I intend to sell it and pick up another in the UK this year. In the UK, cars rust from the bottom upwards. In Malta, they rust from the roof downwards because on an island 17 miles by 11 miles, nowhere is immmune from the salty effects of the Med.
Here, a lot of people are 'boat-happy' with a large marina and plenty of shops selling boat accessories. I've known for a long time that ships have sacrificial anodes/cathodes welded to them so I went into a shop to ask about these.
They range from 2 in a bubble pack for 7 euros, up to things you need a flat bed truck to carry away.
Has anyone any views, experience, comments, etc whether a 10 euro sacrificial cathode bolted to some part of the car body making good electrical contact would be harmful or beneficial?
Car manufactureres don't use them and rust inhibition is done by other means. If I were a real sceptic, I'd say 'of course, they want car bodies to last for no more than a few years', but many makers do go to lengths to inhibit rusting. If car manufacturers are not all that evil when it comes to rust, why are there no cars with these things?
Regards to all,
alienx
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: INHIBITING RUSTING OF A CAR BODY
03/28/2009 5:32 AM
Zinc works for Electrolysis on steel boat hulls in water. Cars are more of a rust problem--I have spent thousands of hours painting boats which have both.
Electrolysis is local contact between two dissimilar metals.
My advice is to remove all the rust and then coat the steel--The case of: An ounce of prevention is worth a pound of cure. Once the original coating fails and the steel starts to rust and you coat over it, it will scale and continue to erode. A coat of zinc paint will slow the process, but will eventually be consumed and then start back on the steel. The zinc is as you stated, sacrificial, whether a paint or zinc bar.
Your real problem is rust and the only real cure is prevention from a coating, not cathodic protection. I have researched this here and got some good information-along with years of doing maintenance on a well kept vessel.--We had hundreds of zincs, but only where the steel was submerged or flooded in sea water.
Sandblast the rust and coat it or let it go-Rust never sleeps Regards, K T
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
03/28/2009 10:20 AM
AND a Neil Young fan, I'm impressed.
Charlie don't surf.
United States - Member - Member Engineering Fields - Mechanical Engineering - Member
03/28/2009 5:11 PM
Buy a Corvette, newer ones have aluminum Frames, supporting the Fiberglass bodies, then all You have to worry about is damage from Sunlight to the Gel-Coating.
"Don't let those telling You, it can't be Done, stop you from Doing IT", Albert Einstien...
03/28/2009 11:38 PM
I'm not sure that this will work in your application. Typically the sacrificial metal (in this instance zinc) is isolated from the base metal and contact occurs through the galvanic activity that occurs during submersion in salt water. (A result of the oxidization process). Possibly some form of aftermarket galvanization (there are several aerosol products available) could prolong the agony some but such coatings will need to be applied prior to painting.
Have you considered marine coatings? The upper parts of ships are made of steel, exposed to direct salt air and harsh environments and do not benefit from sacrificial plates. These exposed surfaces must be protected by their coating alone.
Being from the U.S. I'm not familiar with GB plates. Could you explain?
03/29/2009 4:36 AM
_________________________________________________
GB = Great Britain, He means the Car He drives is registered in a Republic of The Empire, quit embarrassing us...
Good Answers: 97
03/29/2009 4:41 AM
Great Britain maybe?
Good Answers: 196
03/29/2009 12:17 AM
I have several suggestions.
One is a car cover of a water repellent synthetic fabric. We've used one on my wife's 99 Lexus, that sits outside all the time. (http://www.calcarcover.com/)(their "WT" grade fabric) The car still has the wax the dealer put on it when we took delivery. This suggests that in your environment such a cover may do well at keeping the salt away from the body seams.
Another possibility is the periodic application of a light mineral oil like automatic transmission fluid to the external body seams or perhaps the entire exterior. There could be an issue with compatibility of the oil with plastics and rubbers in the car body. Perhaps a vegetable oil (olive oil?) that is good for that. I would ask around the island about whether the old timers like that approach.
Check out a product called Salt-X. Google it for info and sources. Check ebay. I've found at least one ebay seller of fishing gear that ships internationally and sells Salt-X. I've had no experience with it yet but a lot of friends who regularly visit one of the the salt covered desert areas of the western USA swear by the stuff.
Ed Weldon
Good Answers: 97
03/29/2009 12:28 AM
I'd put my money on polysiloxane
Good Answers: 196
03/29/2009 12:51 AM
bwire ---
I googled polysiloxane and it seems that its big application is as a concrete sealer. I got the impression that it cures or hardens. Is that what you're thinking of? Do you have any experience with the us of this stuff on things like steel car bodies? Any good links that tell that kind of story?
Ed Weldon
Good Answers: 97
03/29/2009 4:38 AM
Did you follow the hyper-link? Did you google Acrylic Polysiloxane?
A Patented (US 6, 281, 321 and
EP 0 941290) Polysiloxane finish coat
• Provides unrivaled short, medium and
long-term color and gloss retention
• Offers the same high performance
anti-corrosive protection when used
in an approved two coat system as
that achieved with traditional three
coat systems
• Good abrasion and impact resistance
helps reduce damage during service
• Long term flexibility makes Interfine 979
ideal for use on thin gauge steel
fabrications.
I've lived on a few islands where salt spray corrosion was always taking shine out the waxing on the cars. I don't recall the product name that is used in the inner auto body cavities which has wetting properties. Often it seemed the body panels rusted from the inside out without it.
There was a liquid product called "Blast-Off" we used to remove and stop the oxidation before painting too.
03/29/2009 5:01 AM
My thanks to everyone who have so far replied.
Alan.
03/29/2009 6:02 AM
Sure, No Problem
Good Answers: 117
03/29/2009 1:48 PM
Rusting of auto bodies...I think billions of dollars have been spent on fighting this problem. All that money means that whole industries have arisen dealing with it, and they like it that way.
Steel. A fine example of low upfront cost, leading to high maintenance down the road. Fiberglass is difficult to engineer crumple zones...or so I have been told. I don't think you can create a unibody auto body with fiberglass...you always need a frame. Stainless steel...hard to make a good box frame from stainless steel...cracks propagate too readily in it, requires heat treatment to stress relieve...adds a lot to the price. Once you have the frame, you can put a wood body on it if you want...or a sisal-resin body...or a fiberglass body. But the clips and screws will all be of steel, and they will rust. Can't win for losing here...its all a trade off.
Here in Canada, the roads are covered in salt brine for half the year...quite possibly the worst possible environment you can have for motor cars. Our answer is to touch up rust spots as quick as they form up top, and to oil spray the underside. Oil seems to work as well as most anything else, however professional companies exist who drill little holes all through the body work and fill up fenders (wings), quarter panels and odd spots which they know trap moisture. The professionals usually know where and how to do this best, though of course, there are plenty of "fly by night" companies who will do a cut rate job for a cut rate price with cut rate results.
The auto companies, led by Ford, are using galvanized steel thoughout nowadays. Modern cars are sold with a rust proofed package as a sales feature, and generally speaking, the factory rustproofing is pretty good. It is a little startling to see the expensive imports develop rust spots in a year or two, and the bad old American cars are doing fine. Of course, any coating must be there in order to work...chips in the paint, and micro cracks which let in moisture are common in stress areas (like around window corners) and paint formulations which work fine in temperate climates like Germany or the UK develop tiny cracks due to the different co-efficient of expansion when the temperature fluctuates between +20C in the garage and -30C outside a couple of times per day. Moral of this story..use the right paint. grin! The downside of this is that if you have to braze or weld in a new patch, you have to deal with toxic smoke from the hot galvanized steel, and you have to dispose of some very toxic chemicals..even the dust from sanding the paint can be pretty hazardous.
Malta is a special case...dry most of the year, but that salt dust just drifts in, and sits on everything. Then once a year for a month, it is humid and rainy, and the dust suddenly becomes hydroscopic, and promotes rust. I know that the armour on display at the Palace Armoury rusts from the top down because of this phenomonon. Similar armour in a great house in the Lake District would rust from the back forward because the wall it is leaning against is (very slightly) damp.
There is a fellow here in Hamilton Ontario who takes in cars, takes them apart, strips off all the paint, and repairs any rust with weld and braze. The chassis are cleaned, and renewed, new brakes and brake lines installed, new electric bundles run and headliners installed. The operation takes about a month from start to finish. It costs a fair amount...and consequently he usually only does it to "classic" cars. Most any good "panel basher" in Malta could do the same, or an abbreviated version of it. How much to you value your car?
03/29/2009 5:13 PM
Great and informative.
Thanks,
Alan
03/29/2009 6:17 PM
I did, in my travels, run into different products we used that may be of interest--
Ospho™--Phosphoric acid--works on rust and bleed, but any scale left and it's only temporary and you still have to remove the root cause of the rust.
Aluma Brite™--Another acid that is designed for Aluminum, but works good for cleaning the rust bleed that discolors the marine paint.
Corroseal™--Not sure what it is exactly, but we found it at the end of my fishing career and I didn't get to see if it would stand the test of time--It did a combination of things--we could scale the rust and paint this stuff on. It turned any rust purple and then formed a plastic coating which we could paint over.
I had to paint a 110' boat, stem to stern, every year(two part, three coat system). It was only worth doing, if you do it right. Once you get behind on the rust, it took several years to get it back under control.
Good Answers: 123
03/29/2009 11:27 PM
I repainted an old Dodge van years ago. I used Ospho, combined with a rust prep coating that was sold and recommended by Dupont for use on reused bare metal areas. I covered it with epoxy primer, followed by Imron paint. There was no paint on any of the roof when I got ti. The paint showed no signs of the rust after 8 years of Florida sun. When I sold it it was as good as when I painted it. Lots of words, but I believe Ospho works well.
Another product out there is called Extend. It is designed to convert rust into a weatherproof coating. Eastwood sells another product called Por-15 that seems to be popular with people restoring older cars. I have had very good results using a product called Corrosion X. It is in an aerosol can , and dries to a wax like substance. I have used it inside some rust prone areas around the shop.
If I tow around an old Ford, will it serve as a sacrificial anode to stop my Chevy from rusting?
Bob
Good Answers: 117
03/30/2009 10:07 AM
Thank you. Very kind.
03/29/2009 10:03 PM
Fiberglass might not make good frame rails, but a similar (stronger) product such as "Carbon Fiber" is gaining popularity, and with it lower costs. I believe Lotus makes a two-seater Carbon Fiber car now that isn't available in North America, probably because of the rigidity of it in normal crash tests.
But if You want to bring up older American cars, the frames/body panels were overbuilt that is why they last longer, and weigh so much, nobody gave much thought to lightening the weight until they went racing, or were looking to save at the pump. Some racers even dipped whole bodies in acid bathes to thin the metal panels to paper thin sheets, to the point where driving the car in a headwind would make the panels ripple, and make noise.
When Japan started making Cars they concentrated on making the cars as lightweight, and cheap as possible to flood the market with cars that got twice the fuel economy as an American/European counterpart. Thus You wind up with a car made from very thin stamped steel, which if rust starts is very hard to overcome.
Now China is getting into the fray, but their biggest problem seems to be in quality control of the alloys they produce, some products may be suffering from Lead being in the Steel the way it seems to break so easily.
______________________________________________________________
The future seems to be in hyroformed aluminum, or fiber/resin frames, and a whole myriad of choices in composite panels.
Good Answers: 117
03/30/2009 2:18 AM
If it was only about weight, I would say, "sure, bring it on". I would need a lot of convincing to believe that the few ounces saved by using carbon fiber would actually save much fuel. I DO believe that a ligher vehicle will stop quicker...a very important consideration when racing, and for safety on the street. However, auto body design has so much more to it than aesthetics. Some of the reality shows on TV have a lot to answer for because they tend to ignore simple engineering considerations. A lot of cars are "unibody", like an aircraft. The body is actually the chassis, or frame if you prefer. At least in whole or in part. Most of these "considerations" have been addressed, and resolved, more or less in modern steel automotive design.
Price....painted steel is pretty cheap, especially compared to stainless.
ease of manufacture....steel can be stamped. It can be formed really quickly, without long cure times that resin based equipment with minimal worker (and possible error) input.
Less labour in manufature.
Steel fenders and body work are designed to crumple under impact, providing a cushion which absorbs energy. There are many different directions that the impact can come...like rollovers, and sideswipes. Most of these requirments are government mandated, and all the engineering work has been done. A new material, even fiberglass (which is not all that new) will have to go through a lot of testing to meet the ever changing regulations.
The steel rails are designed to hold the heavy engine in place, away from the passenger compartment. When they give way, they are designed to direct the hurtling engine away from the cabin. This involves bending in predetermined ways. Fiberglass or carbon fiber don't really DO the "bending" thing...
Carbon fiber is lighter for the stiffness you get. In an accident involving an aircraft (which was riddled with carbon fiber), we in the air force were told to beware of the toxic nature of the material, and masks were only the first level of defense. Wrecks with carbon fiber panels broken all over the place were hazardous because the way the stuff broke it was a nasty pile of needles lying in wait for any rescuer. The dust which blows up , don't get it in your eyes....
Steel is more easily repaired in a minor fender bender. Fiberglass simply fails, and carbon stands up really well until even it gets destroyed, but by then it is catastrophic.
Steel can be shifted and dragged back into place in manufacture or repair, and a crumpled fender will still function as a fender. Crumpled fiberglass doesn't shrug off a few dents like steel will. I dragged my fender away from the tire once, and drove that car for a long time...it sort of "oil canned" back into place. No cost repair. Gotta love that.
Steel can be welded to repair a hole. Of course, fiberglass can be filled as well. If the hole is in a stress panel, the weld will stand up pretty easily. Fiberglass can be repaired in much the same way.
Cars made from steel can be crushed, and remelted into new cars. Fiberglass just fills up landfills.
Surprisingto some, fiberglass is heavier than steel for most robust applications...carbon fiber is light, but in either case, it is not the weight of the fibers, but rather the weight of the resin. Because carbon is so much more expensive, it tends to be made with a little more care, a little more engineering has gone into it. Read...expense... This expense is not minor consideration either! No body makes carbon fiber "chop", for instance. (or maybe they do...but the question would then be, "why?) Gel coat and chop are the way to go, assuming you want to go that route.
When I was rear ended a couple of decades ago, my rear tail light was broken. The fiberglass fenders and hood of the car that hit me exploded into tiny bits. Admittedly, the temperature was well below freezing. Fiberglass reacts differently when the temperature fluctuates wildly. That makes it use in stress panels difficult to engineer. The guy that hit me was faced with a huge repair bill. My tail light globe needed to be crazy glued back together.
Resin panels support combustion.
Fiberglass panels don't rust. However, the bolts and screws used to hold on everything from door harware to window trim DO rust.
Well, these are some engineering considerations. I didn't realize whien I started this list how biased it was away from fiberglass. But to understand why fiberglass is not used as much as it probably should be..well, this is a start.
Interstingly enough, I was talking with a fella a few years ago who was traveling in Africa. He noticed that there is a lot of sisal which some of their best and brightest were using to weave into very coarse cloth, or mat. Then they would soak this mat in resin and mould it into body panels, barrels, and a thousand other things. It wasn't super light, but it WAS super cheap, very resistant to fungus, moisture, and damp. I wonder what ever happened to this project.
03/30/2009 5:28 AM
Quote:
If it was only about weight, I would say, "sure, bring it on". I would need a lot of convincing to believe that the few ounces saved by using carbon fiber would actually save much fuel. I DO believe that a ligher vehicle will stop quicker...a very important consideration when racing, and for safety on the street. However, auto body design has so much more to it than aesthetics. Some of the reality shows on TV have a lot to answer for because they tend to ignore simple engineering considerations. A lot of cars are "unibody", like an aircraft. The body is actually the chassis, or frame if you prefer. At least in whole or in part. Most of these "considerations" have been addressed, and resolved, more or less in modern steel automotive design...
Whoa, Captain Steel...
This thread is about corrosion of the Car body, not the Cost, or economy of the Car, in My Comment I did mention fuel economy, but only showing the changes in Automotive manufacturing over the last 40-50 Years, sorry if I strayed.
My first Comment was to suggest a Corvette, which is neither Fuel Efficient, nor Cheap, but it is corrosion resistant. The newer ones have the Hydro-Formed Aluminum frame (I mentioned), with Fiberglass bodies.
Yes there is steel in the mix, nuts & bolts, but a nut/bolt is 20-100 times thicker material than a typical steel body panel, hence they don't rust too quick. When they do show corrosion, replacing a bolt is way cheaper than a typical fender. YES if the bolt fails it will cause damage to the fender... A normal maintenance schedule spots bad hardware before a catastrophic failure.
Yes Steel is the cheapest (will be for a long time to come), but not the most practical when discussing corrosion resistance.
And Fiberglass, and Carbon Fiber can both be recycled, it is ground into a powder, and then fed to the machinery that made the original thread/cloth. And the toxicity of either depends on the resin used, Glass, & Carbon by themselves are non-toxic.
Yes You can poke Your skin with a Glass, or Carbon "Needle", but guess what, You can cut Your Hand OFF on jagged steel.
Link to a random Carbon Fiber seller on eBay
(Not intended to endorse a specific seller, but I did like the Guy's pictures.)
Last time I was rear-ended I got a scratch on My Car, but I could care less, the time before that, The poor fellow's plastic bumper had to be pulled off of My Class 4 Hitch. I laughed...
I paid $80 for This Car, of course I spent more putting the wheels, tires, and other accessories on it, but what do I care about corrosion? I live 10 miles from the Gulf of Mexico, but that is far enough away not to affect the Car much if any, and I wouldn't care if it did. The Sun did the damage to the Paint.
I also had to find a used $20 Fuel Pump to put in the Gas tank when I bought the Car, allowing Me to average about 22MPG on the Highway with the 5.0L EFI Engine (but we shouldn't be talking about the economy), And with the 31 inch tall tires in the rear I got about a 12% increase in efficiency on the Highway.
I don't have a corrosion issue, the Guy in Malta does...
Good Answers: 117
03/30/2009 11:39 AM
Ah well, we did stray off the issue, didnt we. Well, maybe we did. You suggested that he should get a car that didn't rust, and suggested glass. I responded that I love glass and that generally lighter was better, (though glass may not necessarily be lighter), but there are problems, and pointed them out.
Now here you are getting real defensive and calling me names. Mind you "Captain Steel" is not as bad as what I usually get called, in fact, its a compliment...call me THAT anytime... :)
Sorry about straying from the point.. Tell ya what, the people reading our posts can mark us both off topic, okay?
(weight, by itself, does not cause inefficiency in rolling vehicles. If it was, then trains would not be as efficient as they are. Taking the golf clubs out of the trunk won't give you measurable better gas mileage. Washing the air catching dried mud off your car will. going lighter on the brakes will. Taking the stuffed animals off your hood when you are driving will. (oh here I am sounding mean again when I am just trying to be funny...grin.)
So what part of my post, besides its being off topic, did you think was in error? I thought I had done a good job in documenting the reasons why we still make and use steel cars instead of fiber-resin vehicles, and that I thought that corrosion resistance quite properly took a back seat to several more important design and engineering considerations.
Corvettes are, as you pointed out, a special case. They are thouroughbreads, and need special handling. My neighbour owned a corvette in Prince Edward Island, a climate much like Malta, but wetter and colder. He was plagued with corrosion problems...his comment to me was "yeah, YOU can rust proof your car, but the little steel clips which hold this car together can't be rust proofed. They are thin metal, and rust just like any other car." He also had a problem with his door hardware which unaccountably broke right off on him one rainy spring day. We don't know why....it is just a fiberglass-in-the-cold thing I guess. He operated an ocean going fishing boat made from fiberglass with no troubles though.
03/30/2009 11:48 PM
As an Olive branch I have marked My last post (and this one) off-topic as You Have done on Your latest, I'd say Steel will be with us for a long time to come, and new ways of using it are popping up... But composites are on the rise.
In 20 Years We will all be on Mandated Lithium, and move around Town by standing on moving sidewalks like they have at Airline Terminals.
I was trying to be funny by the title "Captain Steel" as you may, or may not have understood, You do appear to like it though. I don't want to make You an Enemy, I'm sure You have a vast wealth of experiences that I do not have, everyone on this Planet has something to teach. I also hope You understand that My points have merit as well.
I am unemployed so I am not here to endorse any product, or service, and I am pretty sure You aren't either. I have filled in quite a bit of info on My Profile if anyone is curious why I am Here on this Forum.
_____Shake on it,___________Pardner.____
I wish I would stop clicking the left button when adding an image... It cancels it.
____________________________________________________________________
I have found some of the posts in regards to Specialized Sealants/Paints to be interesting, even though I poked Fun at one.
03/29/2009 9:09 PM
Suggest you get a car that utilizes 2 side galvanized sheet in its manufacture, or one with a fiberglass body.
03/29/2009 11:53 PM
I have seen advertisements of a system that you clean off an area of about four square inches of the frame down to bare metal and attach a sticky pad which is connected to some sort of black box that you plug in that reverses a small current and prevents corrosion of anything electrically connected to the frame. I have seen this on a television show here in the U.S. called Two Guys Garage but can't seem to navigate to any information about that product. It is marketed to car collectors and I have seen it in use a few years ago.
Nothing exceeds like excess.
03/30/2009 5:54 AM
Complete Scam, every conductive piece of Your Car's frame/body (if Metal), is electrically/physically connected to the Negative Post of the Battery. Which cycles Hundreds of Amps of current per hour.
Do You think any device You connect to the Metal Frame/Body will Have any effect on that charge. Especially if it's power source is the Car's Battery...
If it is powered by a Large outside source, like the A/C Source in Your wall outlet You could only use it while the Car is parked in Your Garage, and it still won't do squat!
03/30/2009 3:05 AM
what you describe is a sort of cathodic protection of a car body. This is not possible 'cause cathodic protection works only if you havea a metal placed inside an electrolyte, like a boat in water or a pipe in soil .Cathodic protection will not work in the air.
Also what you use is not a cathode but an anode that protect the metal (the cathode).
S
corrosion protection
Good Answers: 97
03/30/2009 5:57 AM
http://www.zero-rust.com
ZeroRust Performance:
Continued refinement of the Zero Rust formula has netted ASTM-B117 salt spray testing results exceeding 2000 hours at 3.5 mils dry film thickness (d.f.t.). This equates to 600 hours per dry mil, which was previously unheard of in an air-dry system. The Zero-Rust rust protection performance exceeds that of commonly used red oxide, DTM Acrylics, water-borne alkyds and epoxies on these types of surfaces. Zero-Rust rust protection performance has been confirmed by industrial, commercial and marine industry. Black and Red Oxide Zero-Rust are recommended as the primers for corrosive services -- including marine, coastal and industrial surfaces. The effectiveness of Zero-Rust on bare steel surfaces is optimized at 2.5 to 3.0 mils d.f.t. over profile. Rule of thumb: Zero-Rust should provide five years of rust protection for every a mil d.f.t. With the addition of a topcoat or a thicker film of Zero-Rust to take the ultraviolet rays, sealing protection can easily double.
03/30/2009 11:03 AM
This Bag is 3 mils thick:
But if it gets cut, Your Balls are gonna get Wet!
Good Answers: 62
03/30/2009 9:44 AM
Or you come to the States and buy a Delorean!
03/30/2009 5:30 PM
Try googling " electronic rust control " and read the info. there.
They are selling a lot them here in Canada.
Prices are about $ 200.00 Canadian and they are very easy to install .
The Navies of the world have been using this type of rust control for years and it involves simply introducing a very small constant trickle charge to the metal body of the vehicle ( or ship ) to stop the rusting process.
If it works for them, then i submit that it is probably worth the $ 200.00 bucks to try it out. The system is also easy to transfer from one vehicle to another so you only have to purchase it once.
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
Good Answers: 97
03/30/2009 5:45 PM
Wouldn't dragging a ground strap essentially produce similar results?
Good Answers: 117
03/31/2009 3:02 PM
I so agree. Two bills is nothing compared to the cost to repair body damage due to road salt.
On the other hand, this is controvercial. What would be needed would be a good test, like a taxi company with a fleet who would be willing to have half their cars equiped with these rust control gadgets, and the other half left as control samples. I know the ones you refer to for ships. I don't know much about their applications in cars, and the product literature seems to be written by the sales departments.
04/01/2009 4:12 PM
See Strider6's Post regarding cathodic protection above.
In Navy (& other) Vessels, the salt-water is an electrolyte, And the Boats do not use the Hull as a Ground conductor for the electronic circuits.
Good Answers: 196
03/31/2009 2:22 PM
Just for general interest I'll describe the anti corrosion features in the best purpose built cars for landspeed racing on the Bonneville Salt Flats. My comments exclude the obvious construction of the body classes (mostly lower speed) that require actual production bodies. The Bonneville Salt Flats summer environment ranges from desert dry with windblown salt dust to wet with puddles of standing salt brine that is impossible to keep out of the lower portions of any vehicle traveling over it at any speed over a walk.
Temperatures range from 20C to 35C during the day and night. Violent thunderstorms accompanied by winds up to 120km/hr are one or two times a month occurrence. Afternoon dry winds of 20-30km/hr sufficient to raise salt dust into the air are a daily summertime occurrence. The total time that race cars are exposed to this environment ranges from 150 to 500 hours per year. The remainder of the time is usually spent at home in covered storage, often in very humid local climates.
About relevant car construction:
Frames of essentially a deep space frame like construction due to roll cage requirements are welded low carbon steel tube and some plate. All ends are welded closed. Frames and most suspension members are professionally powder coated to thicknesses on the order or 0.25mm to 0.50mm. Frames and suspension members do flex and coating cracking leading to corrosion is seldom if ever seen. Where surfaces of suspension members are not coated because close tolerances must be maintained annual inspections are warranted. This usually occurs immediately following the end of the competition season in the late autumn.
Bodies of aluminum 3003 where compound curves need to be formed and/or welded or 5052 where they are flat or simple curves. Fiberglass or other composite body panels function for the most part as aerodynamic outside features. Typically driver compartments are lined front, back and sides and bottoms with additional aluminum panels fastened to the frame structure.
Removable steel and cast iron chassis components are all powder coated. Threaded fasteners of stainless steel with locking features (plastic inserts or safety wires) are preferred; but alloy steel is usually used where special and larger fasteners are used such as in suspension and drive train components. In all cases best practice is to coat all threads with grease or antisieze compound to exclude salt and moisture and facilitate easy removal.
Zinc plated Dzus quarter turn type fasteners in sizes 5 through 7 are the preferred method for attaching body panels, both aluminum and fiberglass, to provide easy maintenance access.
For electrical components, especially connectors, high grade marine components are preferred. Careful application of dielectric grease to all electrical connections is best practice due to the presence of large amounts of windborne salt dust in the Bonneville environment.
Absence of conventional upholstery in purpose built race cars plus an application that does not require sealing for operation in bad and rainy weather means heavy wash downs with water to remove salt residues are practical and will not result in pockets of water that won't drain.
Does this sound like your everyday car that you'd prefer have all the comforts and conveniences of a small family room? No. But there are still some ideas worth looking at here. This is real world experience and represents a gradual evolution of racing equipment in this strange environment since 1949.
Ed Weldon
04/01/2009 4:20 PM
Outstanding Post!
And Just think, He could lap Malta in 15 Minutes... Or Less.
Register to Reply 35 comments
alienx (2); Anonymous Poster (1); bob c (1); bwire (5); crimich13 (1); Cyberfool (10); Ed Weldon (3); edignan (1); Jaguar (1); Kilgore Trout (2); machine head (1); stevem (1); strider6 (1); Yusef1 (5)
