Previous in Forum: Check List for Crane Operators   Next in Forum: Industrial Grinder Dust Control
Water Pump - Motor Turns Off
04/03/2009 10:36 AM
hi everybody,i have a 380 vts 4.00k ws grundfoss motor which am using with a submersible bore hole pump.the motor starts well after pumping water for about ten minutes.the motor draw more current and a 45amps.three pole mcb turns off.members what might be the problem?
Re: water pumps
04/03/2009 10:45 AM
Does the well empty to the point where the pump suction draws air?
Re: water pumps
04/04/2009 8:14 AM
Hi PW,
I can see it overheating if no cooling water,would expect sensor to shut down pump but not see extra amps being drawn.
Possibly bearings overheating causing O/L due to binding, or pump sucking up silt.
How many times has this pump been used with this problem? 5 or 6 or all year many times? bearings would have collapsed if it has been many times I would have thought.
A bit more info please.
Re: Water Pump - Motor Turns Off
04/05/2009 2:56 AM
What sort of "head" are you pumping to? If its a tank, do you have an automatic valve anywhere?
04/06/2009 3:24 AM
Is it running sdrawkcab?
04/11/2009 7:45 AM
thanks ,am pumping the water to a trough for animals.the flow rate is ok as per the available manual .the pump operates for only ten minutes and it goes off.when i replace the motor with another one i donot get any promblem, i really want to know what might be wrong.
04/11/2009 3:32 PM
Simply not enough info. Start with a picture and a technical run down of the pump and the way its connected to both water & power......
Register to Reply 6 comments
Andy Germany (2); garth (1); nzioka (1); PWSlack (2)
You might be interested in: Water Pumps, Submersible Pumps, Submersible Mixers
