Previous in Forum: definition of P number   Next in Forum: Wanted: Small Quantitites of Tedlar
17 comments
dossolvable plastic film
04/05/2009 11:54 AM
I saw dissolvable plastic film. The person who has it, himself doesnt know what exactly it is. Please inform me.
thoughts becomes things.
Good Answers: 243
Re: dossolvable plastic film
04/05/2009 1:07 PM
What was the solvent that it disolved in? Water? Acetone? MEK?
milo
Good Answers: 97
04/05/2009 2:07 PM
Dissolvable or biodegradable?
Good Answers: 243
04/05/2009 4:09 PM
Good point.
milo
04/05/2009 7:14 PM
Water will dissolve PVA, poly vinyl alkoxy (alcohol), and not much else.
MEK, acetone will dissolve acrylics, styrenes and after a while swell others.
Toluene will swell and dissolve silicone resins, slowly.
That's all I know.
04/06/2009 2:48 AM
In addition to the above,
  • toluene and butanone will dissolve polystyrene.
  • trichloromethane is used as a solvent to join PVC and ABS
so what plastic material is being discussed, please?
04/06/2009 10:29 AM
"so what plastic material is being discussed, please?"
That's the question. We're guessing, due to the lack of information. The OP doesn't know either.
Good Answers: 243
04/06/2009 10:44 AM
...and why we asked for the solvent...
milo
04/06/2009 11:00 AM
Google "Solvy"...Buy it at a fabric store.
04/06/2009 11:29 AM
Hi,
It's PVA film. Available all over the place, just google it. Also available as spray-on or roll-on dispursions.
Poly vinyl alchohol films are resistant to a great many other solvents and are used as mold releases for the composite business. They are great barrier films as well, so they are used to coat the inside of hydrogen storage tanks too.
Cheers,
Bloefeld
bloefeld
Good Answers: 42
04/06/2009 12:22 PM
Sandeep Lokhande,
If water soluble/dissolvable plastic films/sheets are your interest,well the answer is yes.
For dry powders/materials handling and disposal after use polyvinyl alcohol films[which replaces traditional polyethylene films/covers] are applicable to enhance water solubility and disposal .Such films are commercially available.
Check the film of your friend for water solubilty and report.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 38
04/06/2009 8:36 PM
I remember PE(Polyethylene) bags are recyclable, maybe it is that?
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
04/07/2009 5:37 AM
Hi sandeep,
it's exactly what you named it. been around since 2001. it's also called "edible packaging".
check out the following sources:
tell your friend you know what it is.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
04/07/2009 9:19 AM
It's been around much longer than 2001.
In the '70/'80s we used plugs made from PVA to seal the scuttle holes in sonabouys deployed from the air.
After a few days in service, the plugs would melt, and the device would sink to the bottom of the ocean.
04/07/2009 1:15 PM
what is this sonabouys?
04/07/2009 1:29 PM
Electronic listening devices used to detect submarines, and other underwater noises, too, I guess. They were dropped from helicopters or planes in searching for "enemy" subs.
They were battery powered, so their life was rather short. We formulated the plug to last just a little longer than the batteries. Then it sank to the bottom.
Good Answers: 38
04/07/2009 9:17 PM
i did not get it either the first time i read it you mean sonar buoys
Good Answers: 58
04/08/2009 5:47 AM
same thing. you forgot he's got a British tongue pen.
Register to Reply 17 comments
Anonymous Poster (1); bloefeld (1); Epke (2); Hendrik (1); langyaw (2); lyn (4); Milo (3); PWSlack (1); s.udhayamarthandan (1); sandeep lokhande (1)
You might be interested in: Saw Blades, Plastic Sheet and Plastic Film, SAW Filters
