Previous in Forum: Antipumping Relays   Next in Forum: over voltage alternator.
9 comments
Power Factor Correction
04/08/2009 12:01 AM
Could anyone supply me with info on how to calculate the average power factor, average power, KVA and KVAr and of a three phase system if a single phase power quality meter was used to measure the power and pf on all three phases, individually.
Re: Power Factor Correction
04/08/2009 12:56 AM
jorpaul; what kind of power quality meter do you have? 3 phase 3 wire 2 single phase meters, 3 phase 4 wire, 3 single phase meters required, perry
04/08/2009 12:58 AM
dEAR,
All being scalar parameters,
Average pf pf = (pf1 + pf2 + pf3 )/3
Total KW load = (kw1 + kw2 + kw3 )
Total KVAR = ( KVAR1 + KVAR2 + KVAR3 )
Total KWH = kwh1 + kwh2 + kwh3
Exploring the Science of Electricity
Good Answers: 103
04/08/2009 4:35 AM
Thinking about it, assuming Vi and Ii being phase to neutral voltage(assuming Y connection) and line currents,
KW1 =V1I1CosΦ1
KW2 = V2I2CosΦ2
KW3 = V3I3CosΦ3
KW = KW1+KW2+KW3 =V1I1CosΦ1+V2I2CosΦ2+V3I3CosΦ3
In case of balanced then
KW = 3KWph = 3VphIphCosΦ
but it isn't is it ?
04/08/2009 3:00 AM
Ah! CR4's favourite topic: power factor.
04/08/2009 3:31 AM
Now a days multi function meters are available in the market.you can connect to your supply .You will get result.
04/09/2009 2:03 AM
Dear all,
3phase power measurement by single phase power meter.
1 Connect volt probe to phase A and B
Connect amp probe to phase A.
Recored KW and KVar
2 Do not remove the volt probe at phase B, but move the volt probe at phase A to phase C.
Move the amp probe from phase A to phase C. Do not change the direction of Amp probe.
Recored KW and KVar
3 Total of both kW above is 3phase kW
Total of both KVar above is 3 phase kVar
3phase KVA is sqrt(sq(3phase kW)+sq(3phase kVar))
3phase PF is (3phase KW) / (3phase kVA)
Regards
Akihito Shigeno @ JGC-Indonesia
04/26/2009 5:29 PM
Thank you, very profound.
04/09/2009 4:42 PM
Power Factor (PF) is equal to the cosine of theta. Draw a right triangle with True Power (watts) on the base (side Adjacent) Reactive Power (VARS) on the vertical (side Opposite) and Apparent Power(KVA) on the hypotenuse. Use Trig to solve. The cosine of angle then should be expressed as Percentage and this is PF. A good PF for AC power is 95% (lagging- inductive) never go over 100% for utility supplied power, this would be leading (capacitive). So if reactive power goes up in relation to resistive power, then phase angle increase and PF decreases. So if angle theta is 25 degrees the Cosine is .9063 so the PF is 90.63%.
04/26/2009 2:31 PM
P=VIcos phi,
where cos phi is the power factor
sohail
Register to Reply 9 comments
Akihito Shigeno (1); Anonymous Poster (3); harry potter (1); lavurk (1); perry (1); PWSlack (1); sb (1)
