Previous in Forum: Shear Waves vs. Compression Waves   Next in Forum: Mid-Week Challenge: What Is This Device?
25 comments
Maths.
04/08/2009 10:39 AM
Could some one please explain to me what "log" an "e" is. I've read up on it but I'm still not really sure.
Dreams are the blue print for reality.
Re: Maths.
04/08/2009 10:49 AM
The log (to base 10) of a number (say 2 in the example below) is the power to which 10 must be raised to get that number ( 2 in the eg).
EG. the log10 of 2 is 0.3010
That is to say 10 0.3010= 2
Logs can also be to base 'e' just substitute 'e' for 10 in the stuff preceeding this.
The obvious question is what do we use this stuff for and why???
Well some stuff is naturally linear (say the extension of a spring) and some stuff is natuarally logarithmic (say the way we hear loudness of sounds)
Don't worry that you find it confusing...just about everyone does.
Del (honest to a fault)
Good Answers: 62
Re: Maths.
04/08/2009 11:09 AM
I do have to admit most definitions are somewhat circular
Are you comfortable with logarithms in general? Just asking so I know how to answer best.
Good Answers: 97
Re: Maths.
04/08/2009 11:14 AM
Del has said it all but I will try and help you further
Number Log base 10
1 0
10 1
100 2
1000 3
10000 4
Long ago we used logs extensively to perform (now simple) calculations
If you have to calculate X by Y
you looked up the logs of both numbers and ten add them together and looked up the anti-log
For example 10 x 100 == 1 + 2 = 3 == 1000.
0r for 2 x 5 (hoping that Del's 0.3010 is correct)
Log (2) = 0.3010
Log (5) = 0.6990
Total = 1 and the result is 10.
Re: Maths.
04/08/2009 11:17 AM
I know what is 1+1 and can help myself with the basics. I use "log" and "e" on a daily basis in some work related formulas but I do not know why\how\what they really are.
Re: Maths.
04/08/2009 11:39 AM
It's like a lot of stuff it is to some extent arbitary...we could use any base..and we use it because it is convenient.
I once had a guy spend ages in some psedo mathematical convoluted explanation of why we use hexadecimal...
When the real, simple, reason is that's it's just a way of expressing 4bits of binary as a single digit which is of more convenient than having to use 2 digits as you would with base 10 or Octal...
Re: Maths.
04/08/2009 11:51 AM
Generally "e" is specifically associated with natural logarithm or log natural (ln). With that said... Ug!!!
Perhaps the following link will help some:
http://betterexplained.com/articles/an-intuitive-guide-to-exponential-functions-e/
Half of everything in life is counter-intuitive,,, I'm not sure about the other half yet...
Good Answers: 62
Re: Maths.
04/08/2009 1:02 PM
Excellent link!
Re: Maths.
04/08/2009 1:30 PM
Thanks edignan, I had a basic understanding of e and natural logs, but when I came across that link (in response to this thread), it actually helped me out. It's much clearer now. Funny how that works. :)
Good Answers: 62
Re: Maths.
04/08/2009 1:34 PM
I never know something like when I have to teach it!
Re: Maths.
04/08/2009 12:14 PM
The cool thing about the natural number "e" is that in the function: y = ex
It is it's own derivative, that is the slope at any point found by y = ex, is exactly the same (ex)
Works the same the other way with the integral, the area under the graph of y = ex, from (0 to x) is ex
Re: Maths.
04/08/2009 12:31 PM
Whoops - that is not true about the integral/area (but it is regarding the derivative/ slope)
For example:
On the interval x = 0 ......... 1
Area under ex = e1 - e0 = 2.71828... - 1 = 1.71828....
Re: Maths.
04/08/2009 12:40 PM
eh,,wait a minute,, isn't the antiderivative of 1e = e^1 or e ?
In other words, weren't you right the first time?
Good Answers: 137
Re: Maths.
04/09/2009 4:20 AM
Hello CG
Yes he was right first time. The indefinite integral of ex = ex. The fact that you can get any answer you like for the area under the curve (by selecting integration limits) is irrelevant.
Cheers........Codey
Re: Maths.
04/08/2009 1:04 PM
ok, now I'm confused again. I never did understand that whole derivative of e = e thing. Why isn't the derivative of e = 1 ?
Re: Maths.
04/08/2009 1:42 PM
The derivative of a constant is zero.
The derivative of e to the power of x (ex) is (ex)
Re: Maths.
04/08/2009 2:36 PM
"The derivative of a constant is zero."
Check. e is a constant, not a variable. My mistake.
Which is why "The derivative of e to the power of x (ex) is (ex)" puzzles me.
I guess it has something to do with e being an actual rate/slope and a limit. Kind of like one of those einstein-rosen bridge thingies between derivatives... I suppose I would have to graph it to see it.
So e is both the derivative and integral of e, but only in positive terms (growth). In negative terms (deterioration / decay), e is the derivative of e, but not the integral of e. Right or wrong?
Re: Maths.
04/09/2009 12:29 AM
e is not the derivative and integral of e ....... ex is. See below:
In negative terms, this is not the same.
The derivative of y=e-x is -e-x
Re: Maths.
04/09/2009 12:05 PM
Codey and Guest, Thank You!
Re: Maths.
04/08/2009 12:54 PM
oops, looking back , I realize that the link I gave you dealt primarily with e but not natural logs. Here's another that better explains log natural. Just skip the paragraph on e if you read the previous link, but read the previous link first, otherwise it might not make as much sense.
http://betterexplained.com/articles/demystifying-the-natural-logarithm-ln/
Good Answers: 62
Re: Maths.
04/08/2009 11:33 AM
A log is not an "are", it is a technique for doing very fast, accurate math in your head or with a table,
SO - get in the wayback machine with this knowledge and without your calculator and look at Hendrik's answer again:
log10 of 1 is 0
log10 of 5 is 0.6990
log10 of 10 is 1
100 = 2
1000 = 3
10000 = 4
So far so good?
Re: Maths.
04/08/2009 12:16 PM
eiΠ + 1 = 0
(CR4 doesn't do the symbol for pi very well. π = 3.141592653654......... and i = √-1 )
Re: Maths.
04/08/2009 12:31 PM
Some of my finest Blackberry & apple.
What's the symbol for custard?
Good Answers: 62
Re: Maths.
04/09/2009 1:09 PM
3 pi ?
Re: Maths.
04/09/2009 3:23 AM
Maths is all made up by people too lazy to do it empirically
Re: Maths.
04/11/2009 1:46 PM
8 = 23 (2x2x2) is fairly easy to remember.
Put another way, Log28 = 3 ('Log of 8 to base 2 equals 3')
'Log' is usually taken to mean 'base 10', so Log 8 = 0.903089987 , 8 = 100.903089987
Base 10 is a little more intuitive. 100 = 102 and 1000 = 103 . When multiplied, 100 x 1000 = 100000 = 102+3 = 105 . So, you can see how to simplify multiplication by adding terms.
'Natural log', indicated by ln, uses base e (2.718281828). It can be used in an identical way to base 10 ('Log')
ln 8 = 2.0279441532 ie 8 = e 2.0279441532 = 2.718281828 2.0279441532
logarithms will work using any number as base, but using other than 10 or e will get surprised looks from colleagues.
'e' arises from summing series (Bernoulli/compound interest in particular). When looking for patterns in data, it's sometime useful to plot the logarithmic values. Often this helps establish the mathematical relationship by giving a straight line graph. Nature doesn't multiply by 10's very much, but it likes to compound effects, much like Bernoulli's interest.
It's something like that - I was thinking aloud !
Register to Reply 25 comments
Anonymous Poster (4); Codemaster (1); Curious George (7); edignan (5); Hendrik (1); Kris (1); PWSlack (1); Quobaldt (1); user-deleted-1105 (4)
