Previous in Forum: Happy Birthday Isambard   Next in Forum: Broken Springs and Air Rifles
27 comments
Mobile Phones and Solar Batteries
04/09/2009 4:18 AM
My calculator has a little solar panel and a battery. I suppose it helps the battery to last a little longer. Why don't they have the same with mobile phones?
Dreams are the blue print for reality.
Re: Mobile phones.
04/09/2009 4:24 AM
Power consumption of a mobile phone is probably about 1000 times that of a calculator.
Re: Mobile phones.
04/09/2009 4:40 AM
...and my calculator mch older than my mobile phone. Don't they make better solar panel now than when they made my calculator?
Re: Mobile phones.
04/09/2009 4:51 AM
Yes but only slighty better, cheaper, but not much better..
There are doubtless many teams working on trying to make cheap & efficient solar cells, when someone does it, the world will beat a path to their door (or abduct them all and supress the technology...if you believe all the conspiracy theori ...<click ...brrrrrrrrrrrrrrrr>
Good Answers: 150
Re: Mobile phones.
04/09/2009 11:22 PM
Eh, Del my good kitty, I'm afraid you are somewhat incorrect. Solar panel technology HAS improved, quite measurably in fact. your average amorphous silicon solar cell is only about 8-10% efficient if memory serves. A polysilicon cell is closer to 12-14% efficient. Some years back someone (I forget who) developed an annealing process that improved Amorphous cells to nearly the efficiency of polysilicon, but the added cost of the annealing process also put it on par with a polysilicon cell as well. The problem is that a Silicon cell is most efficient in the near IR range and efficiency falls off quite a bit when you move towards the blue end of the spectrum. This is a function of the electron bandgap of Silicon. Not much you can do with dopants to change that bandgap very much. If memory serves, the theoretical maximum for Silicon cell efficiency is something like 22%. Some labs have turned out silicon cells that can get pretty close to the theoretical maximum but they are still too expensive for the marketplace. There is also the problem that most polysilicon fabs are busy turning out chips which is where the money is. It isn't profitable to devote much time and resources to improve Polysilicon efficiency when you can make more money by turning the wafer into quad core X64 CPU's. Recently someone has started buying ruined/ QC reject wafers from the fabs, grinding the defective CPU layers off them and turning the substrate into thin polysilicon solar cells. Supposedly this is going to bring the cost of polysilicon cells down by recycling defective wafers. But I don't kinow if that came to pass or not.
A division of Boeing which makes Solar Panels for spacecraft has made a multi-layer stack using Indium Gallium Arsenide, that is about 41% efficient (because it tweaks the absorption frequency of each layer for a different wavelength AND it has a layer of lenses on top to concentrate the light that falls on it.). the problem is that the panel costs so much to make it is only viable for use on spacecraft where the extra cost can be justified.
Who is John Galt?
Re: Mobile phones.
04/10/2009 3:43 AM
So, in general you are saying they've improved from 8-10% to 12-14%.
Hmmmm, and I said 'Only slightly'
I think we should start a war over this, I'll bet you open your boiled eggs from the wrong end too.
(Nice link cheers, GA btw)
Re: Mobile phones.
04/10/2009 4:24 AM
That is a good 40% improvement at the top end.
Re: Mobile phones.
04/10/2009 4:58 AM
Yes indeed.
When it filters down from the aerospace industry to be available at a cost effective price for us mortals there will be much rejoicing throughout the land.
(don't think I shall hold my breath tho')
Seriously I'm hopeful that someone will come up with a printable film, organic inks, that sort of stuff...not at all my field so I may be taliking tosh. I think one of the probs is conducting the juice out of the damn things effectively.
Good Answers: 62
Re: Mobile phones.
04/10/2009 2:57 PM
No, I think you are right
If we cannot get whopping improvements in efficiency, then lets find ways to make 'em cheap
And they are.
United Kingdom - Member - British
Re: Mobile phones.
04/09/2009 4:41 AM
Mobile phones are designed to be portable, and they use more power than a calculator, meaning that they would need more solar panels, meaning they would take more space, being less portable. Furthermore, they are cheaper without the solar panels, not by much, but "every little helps"
bondy111
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Mobile phones.
04/09/2009 7:24 AM
They make a seperate unit right now:
Solar_Cell_Phone_Charger
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
United States - US - Statue of Liberty - Technical Fields - Education -
Re: Mobile phones.
04/10/2009 11:27 AM
Gotta love it. It seems that the technology exists, but to Del's point, isn't available. Following Bricktop's link, I checked out several solar powered chargers -- most of them are not available. Advertised, but not available -- go figure.
The problem with solar chargers for cell phones is two-fold:
1) Even though phones are mobile, they are rarely exposed to sunlight. Only when in use as a rule. So having a solar panel on the phone, like on a calculator, doesn't make much sense. ( see Vulcan's comment #6 on this in this blog)
2) The areas where you would use a solar charger are the worst ones for cell phone power usage. If you are in a marginal coverage area -- like when backpacking -- your phone is contantly trying to find a signal and register with a network. This is why batteries seem to drain more quickly in marginal coverage areas than in good coverage.
So, using a solar charger in a marginal coverage area would be better than nothing, but not by much. Using it in a good coverage area would require leaving the cell phone alone for most of the day -- so why have it? That's why most folks plug their phones in at night to charge while they sleep and be available during the day.
The best of both worlds seems to be a solar charger with its own battery that could charge during the day, then have a cell phone plugged in at night. Now, if someone could make one of those at a reasonable price...
The BlueEarth phone (see comment # 19 from rod74h)looks promising but we will have to see how much juice is generated from the solar panels on it. I am betting that for now, you had best not stray too far from the power grid.
"Reality is merely an illusion, albeit a very persistent one." -- Albert Einstein
Re: Mobile phones.
04/12/2009 6:40 AM
"The best of both worlds seems to be a solar charger with its own battery that could charge during the day, then have a cell phone plugged in at night ..."
Better still would be phones with easily exchangeable batteries, then you could cut out the 'middle man' (the battery in the solar charger) and charge one of the phone batteries directly, swapping when the one in the phone shows low charge.
Good Answers: 54
Re: Mobile phones.
04/12/2009 8:31 AM
...charge one of the phone batteries directly, swapping when the one in the phone shows low charge
That's what I do. When I buy a new cell phone, I always buy a spare battery. I also buy a desktop charger that can charge the battery alone. This way I always have a fully-charged battery while the other is in the phone being drained.
I always get a kick when my phone beeps the "battery empty" alert and other people say in a condescending manner, "Oh, poor thing's got no battery power!". Then, I take out the spare, slip it in and smile at them.
regards,
Vulcan
Re: Mobile phones.
04/12/2009 9:43 AM
I used to do that when batteries weren't so good - (my first phone was a black version of one of these:
... but these days I find I don't need to. I just charge at night - or from the laptop (or anything else with a suitable USB hole).
My point was that it'd be a more efficient way of using the solar charging principle.
Good Answers: 54
Re: Mobile phones.
04/09/2009 8:35 AM
When I am outside, my phone stays in a belt pouch. No way for the sun to reach it.
When I'm at work, my phone goes into the desk drawer which I lock so that it can't escape into the sunshine.
When I am in my house...well, it's a little hard to bring the sun inside.
regards,
Vulcan
Good Answers: 62
Re: Mobile phones.
04/09/2009 9:34 AM
When you are outside, you need a hat!
So we'll take bricktop's solar link, plug your solar hat into you phone for travel charging!
Good Answers: 73
Re: Mobile phones.
04/09/2009 9:44 AM
Ed, do you wear that hat in NH?
Good Answers: 62
Re: Mobile phones.
04/09/2009 9:50 AM
On "someone's" advice? I left it at home, only to spend all my days so far wiping the liquid sunshine off my glasses.
Problem right now is the place is way more casual than I anticipated, so time to get the boots (thank god for the boots in all that damned snow) resoled. I'm down to the nails in daily wear.
Good Answers: 73
Re: Mobile phones.
04/09/2009 10:04 AM
Wait a minute, let me get this straight. Your using AZ cowboy boots:
when you need NH snow boots:
What size do you wear. I may have an extra pair in the closet.
Good Answers: 62
Re: Mobile phones.
04/09/2009 10:35 AM
I have survived
and
and now I seem to be short some of these
But I'll probably get by on more of these
But thanks for your kind offer
Good Answers: 150
Re: Mobile phones.
04/09/2009 11:29 PM
Edignan, them slippers just ain't right.... They freakin have TOES! That makes my feet hurt just lookin at em!
Who is John Galt?
Re: Mobile phones.
04/10/2009 1:30 AM
The rim of the hat should be covered with solar cells and the phone should be put onto the top of the hat.
Aged man is not old man...
Good Answers: 18
Re: Mobile Phones and Solar Batteries
04/09/2009 4:37 PM
Maybe this article will make you feel better:
http://cr4.globalspec.com/blogentry/8602/Watts-the-Advantage
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
04/10/2009 6:07 AM
There is the new samsung "Blue Earth"
http://samsungblueearth.com/
I'm sure I heard about some folk researching solar paint a while back.
The sort of stuff you can cover buildings in.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Manufacturing Engineering - Member
Location: Honeydew, South Africa, 26° 04' 50" Lat, 27° 54' 59" Long
04/14/2009 4:37 AM
I have one of these fancy Casio watches with tough solar, triple sensor. When it was sold to me I was told you would never have to replace a battery again. Well guess what?? Wrong!! The battery is busy going (even with the battery indicator showing full) so I can't use the backlight or some of the triple features anymore. Another catch is that the damn battery is extremely hard to find because of its rechargeable capabilities. Sucks. You get a non-rechargeable one but it is 3.0V and the rechargeable one is 2.3V.
Make The Most Of It.
04/14/2009 6:08 AM
I have heard about this problem a few years ago, you need to park the watch every night under a lamp.....costs are horrendous for a watch!!!
Its probably best for a night worker who can leave it charging all day somewhere.....
Good Answers: 150
04/14/2009 7:44 AM
Yeah, and CFL's and fluorescents don't work. Not enough near IR in the light spectrum.
Who is John Galt?
Register to Reply 27 comments
Andy Germany (1); Bondy111 (1); bp01 (1); Bricktop (3); Conrads (1); edignan (4); EElectrician (1); JohnDG (2); Qqberci (1); Quobaldt (1); Rod74h (2); Rorschach (3); user-deleted-1105 (4); Vulcan (2)
