Is there any information about ceramic balls in a ball bearing becoming conductive over time due to the impregnation of conductive materials (mainly carbon steel inner and outer rings and possibly a brass or carbon steel cage)? I know initially the insulation would be great compared to a full steel bearing. You know that if you take a carbon steel wire brush to a piece of stainless you can get it to rust. Does this same logic work for ceramic balls? Would the voltage have to be very high in order for this to be a reasonable issue?
Many people propose the use of ceramic bearings (at a considerable additional cost) for motors and generators. Unbalanced voltages in the windings go to ground through bearings leading to early failure due to electrical arcing. (Please excuse my poor explanation of the origination of voltage source - I'm not a EE) Would a ceramic ball bearing experience the same problem after some time? Going to ground from the inner ring over the surface of the balls to the outer ring (ground).
Does anyone know of any studies that might help explain this problem or duration until it becomes conductive? The only thing I am aware of that can isolate the bearing is the ceramic coating on the outer ring. This to me would make more sense however, it relies on a brittle coating on carbon steel that may flex under changes in load and temperature. The cost of an all ceramic (inner and outer rings as well as balls) would be cost prohibitive.
