Previous in Forum: Fire Suppression Nozzles and Orifice Diameter   Next in Forum: Space Vector PWM Calculations
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Vertical or Horizontal KODs (Knock Out Drums)
04/15/2009 5:19 AM
On what basis we decide whether we need to go for horizontal or vertical KOD?
Atul singla
Pathfinder Tags: Veritcal or Horizontal KODs
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Vertical or horizontal KOD (Knock Out Drums)
04/15/2009 5:22 AM
To get a good separation of liquid is preferable to instal the vessel in vertical position. Also the dimension of demister will be less instead horizontal position.
Look over to the next challenge
05/14/2009 9:52 AM
First of all i am sorry for replying so late...Yeah I agree with you, Vertical position will provide Much space for the separation, moreover the condesate will be clear from the forthcoming fluid. but is there any any particular limit upto whihc we cant use vertical KODs. Because i have seen so many horizontal as well as vertical KODs. Horizontal KODs occupy larger space too. Then why we go for Horizontal KODs or under what conditions.
Atul singla
05/14/2009 10:47 AM
Warning: I know nothing about this subject, so, I cannot comment on whether this is good information or not.
http://igs.nigc.ir/igs/bank-matn/IPS/e-pr-880.pdf - sorry, link no longer available
7.1 General
Conventional gas/liquid separators are usually characterized as vertical, horizontal, or spherical. Horizontal separators can be single or double barrel and can be equipped with sumps or boots.
7.1.1 Vertical separators
Vertical separators (see Fig. B.1-a of Appendix B) shall be selected when the gas-liquid ratio is high. In cases where there is a frequent fluctuation in inlet liquid flow or where re-vaporization or remixing of fluids in the vessel should be prevented, vertical separators should be preferred.
7.1.2 Horizontal separators
Horizontal separators (see Fig. B.1-b) shall be used where large volumes of total fluids and large amount of dissolved gas are present with the liquid. They are also preferred where the vapor-liquid ratio is small or where three phase separation is required.
In cases where limitations exist in vessel size, double barrel separator can be employed.
7.1.3 Spherical separators
These separators are used for high pressure service where compact size is desired and liquid volumes are small, (see Fig. B.1-c).
Mist extractor can be installed in this type of separators.
7.2 Design Criteria
Separators without mist extractors may be designed for gravity settling using Stokes, law equations.
Typically the sizing is based upon removal of 150 micrometers and larger diameter droplets.
For practical purposes, to be in safe side, use of the methods presented in the following sections is recommended.
Lots of other information by googling:-
http://www.google.co.uk/search?hl=en&q=vapor+liquid+separator+design&meta=&aq=1&oq=vapor+liquid+separator
04/15/2009 5:43 AM
If the KOD is a vertical cylinder, liquid/vapour separation will be improved if flow is introduced tangentially.
Re: Vertical or Horizontal KODs (Knock Out Drums)
04/15/2009 4:01 PM
what's a knock out drum?
04/15/2009 6:21 PM
Register to Reply 6 comments
Anonymous Poster (2); PWSlack (1); Randall (1); singlaatul (1); user-deleted-1104 (1)
You might be interested in: Vertical Conveyors, Drum Heaters, Industrial Winches
