Previous in Forum: What Burns at a High Enough Temperature to Evaporate Steel?   Next in Forum: What's the Best Piping Material for This Application?
53 comments
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
Maple Syrup, Maple Sap and Excess Water
04/15/2009 10:51 PM
So I got this happening thing happening with maple syrup which has happened already. Basically it's reducing the amount of water in the sap to get at concentrating the carbohydrate and tannins. I'm stuck with a very traditional way of making maple syrup. The thing is that even after RO'ing 70% of the h2o out it all boils down to .....boiling it down....with heat.
Now, boiling off the excess water purportedly kills off the bacteria and virus', or so I'm told (and don't believe, see below). I have a suspicion that the boiling kills off the inherant vitamins that occur with the spring run. Personally, I would prefer just selling the pure sap (which is deliciously refreshing on its own and makes great cocktails, beer etc) but the law requires me to pasteurize any foodstuffs sold to the public....and the herbpolice get downright upset and nasty if they thinks ones out've their jurisdictidactorialialala..... which is the thing that they do......that's coolcats with me.
Recently, I submitted a sample of the raw sap to a lab and no untoward bacterial or viral infestation was found. Cost me $1000. Given that all equipment is sterile (I use high pressure steam and 90% alcohol and citric acid) and all given parametres of safety are observed I would pose the question whether anybody would know how to crack off the excess water without using heat. This, of course would only address the manufacture of making the syrup without killing off the vitamins.
I'd still like to find a way to bottle the sap without needing to pasteurize it (but that's a topic for another day).
Meanwhile, any heady ideas would be greatly appreciated.
Prophet Freddy has the answer!
Good Answers: 101
Re: Maple Syrup, Maple Sap and the thing inbetween
04/16/2009 1:34 AM
You could heat it to a lower temperature inside a vacuum chamber. Most of the water will evaporate away very quickly. The water can then be condensed and recovered for some other purpose because it's of high purity. Of course, you can also simply leave it in a vacuum chamber and let the water evaporate away by itself without heating; it'll just take longer, that's all.
04/16/2009 8:05 AM
Absolutely. Wiped film evaporators are ideal for this application.
Good Answers: 27
04/17/2009 4:42 PM
I'm thinking, I'm thinking............would the evaporated water condense on the wall of the chamber and drip into a holding tank?
Good Answers: 101
04/20/2009 12:00 AM
The water itself is in the air. It can be condensed in a separate chamber.
Good Answers: 146
Re: Maple Syrup, Maple Sap and Excess Water
04/16/2009 7:56 PM
To your question about method: Boiling is the most efficient method of evaporating water from the sap. Any other method would be lossy in energy terms, take longer, and run contamination risks that would have to be mitigated.
The boiling is not so much to remove bacteria from the raw material, as it is to concentrate the sugars to a point where it is inhospitable to bacteria. Anything with enough sugar in it is "preserved": the osmotic environment is the same as for highly salted stuff: cells can't withstand the osmotic pressure, they lose their water (and their life) to the sugar as they do to the salt.
In the last couple of years, I have had a couple of crocks of maple syrup that went moldy after they were opened. Very distressing (I love the stuff it is a huge treat). The product is, I think, just a notch above optimum in water content, and so is missing the desired 'preserved' characteristics.
I would suggest diversifying into two product lines: boil the bejazes out of the syrup so it is nice and thick and long lasting. Use the raw sap with its unboiled constituents to flavour a water beverage. This is a very marketable idea IMO....
incus opella
Good Answers: 120
04/16/2009 11:09 PM
Maple syrup gets a lot of it's taste for the final stages of boiling down. The sugars caramelize = maple flavour.
Modern maple syrup operations concentrate the syrup by reverse osmosis and add a little heat concentrated syrup at the end for flavour. I hear they overheat, with care, about 2-3% of the syrup for this flavour blending. great care to avoid hot spots is needed, which can create a burned taste, so no direct flames on boiling pans for this concentrate. I suspect a carefully controlled double boiler with hot oil in the outside. You just need it a little over 100 C. If you use a vacuum to conentrate it, you do not get and caramelized sugars, so it tastes sort of woody.
Ultrafiltration that blocks bacteria can make a sterile liquid. It is used for milk here.
Per Ardua Ad Astra
Good Answers: 27
04/17/2009 11:55 AM
That's a good suggestion and one I've been seriously considering. I've seen the membranes used in filtering salt water.
Might I suggest that you keep any opened syrup in the freezer. There are certain moulds which can spoil the product very quickly.
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Chemical Engineering - Member Engineering Fields - Environmental Engineering - New Member
04/16/2009 11:06 PM
Try adding ethanol to the sap or some other "seemingly" harmless solvent to distill the water out as an azeotrope (which will boil at a much lower temperature,for eg in the case of ethanol at 78 degC,thus saving your vitamins!). I don't know how thick the sap is,you could try using molecular sieves if it's not too sticky.
Shalom
Good Answers: 27
04/17/2009 9:57 AM
Hmmmm.....not bad .......not bad........got me thinking.
Hobbies - Car Customizing - New Member
Good Answers: 11
04/16/2009 11:44 PM
pasteurization occurs at above 127F {see FDA charts}
vacuum promotes evaporation at elevated temps
in sous vide cooking vegetables are usually cooked at 183F
there must be a temp where you notice a change in taste
obviously you will have to run a series of tests to find your balance point
the concept of adding a portion that has been processed at a higher temp adds another variable
good luck
04/17/2009 1:21 AM
Dehydration in vacuum - as DVader1000 said
Aged man is not old man...
Good Answers: 27
04/17/2009 4:47 PM
Would you know of a schematic I can look at?
Good Answers: 120
04/17/2009 5:00 PM
if you take 2 sealed container one foot in diameter and 2 feet high with a 3 inch tube between them. Place syrup in one side, and heat gently. The other side you cool. Then draw a vaccuum, 29" Mercury is enough. the warmed syrup will boil and the steam will condense on the other side.
In effect this is what a multiple effect evaporator is with a cascade of pressre stages,. It is used in sugar making.
http://acswebcontent.acs.org/landmarks/landmarks/sugar/
it can be used for syrup, but most places lack the volume to build these things
Per Ardua Ad Astra
Good Answers: 27
04/17/2009 6:35 PM
It appears by the consensus that vacuum chambers are the ticket. I think I'll start of with building a model and work my way upwards. Our facility is capable of RO'ing 4000 gal. of sap per day and the concentrate is cold stored for boiling off later. It is an intensive procedure and requires constant attention.
Good Answers: 120
04/17/2009 6:56 PM
Not correct. scale is the determining factor. Reverses osmosis is far more efficient in many cases. If you can use scrap wood of zero cost, then a wood fired boiler will cost less to run.
For large volume multiple effect evaporators will win.
I suspect a rural co-op might best use scrap wood.
There is also the compressed wood chip market. This has turned waste wood into a cash crop and many people use pressure augers to grind wood through a die into pellets. the heat of the process and the lignin in the wood act as a binder. These are bagged and sold in 50 pound bags to people with pellet furnaces (they also burn moldy corn, which cannot be eaten by man or beast.
http://www.google.ca/search?hl=en&q=%22pellet+making%22+%2Bstove&btnG=Search&meta=
Per Ardua Ad Astra
Good Answers: 109
04/17/2009 4:34 AM
Dehydration in vacuum is really the best you can do.
But be careful: you need heat to boil away the water
and you need either a big pump to bring out the steam as condensing water and use the heat of condensation to support heating energy consumption
or you need a colder space inside your vacuum container(s) where condensation takes place and condensed water is stored and this space cooled a lot to remove the heat.
Best would be to lower the pressure to about 10mbar and use very thin films of liquid as suggested in post no.2 (wiped film) and have some sunshine heating the outside of this container (blackened) to 20°C. Then the heat will easily transferred through the SS-wall of the vacuum container to the inside fluid film. Evaporation from a fluid film is without boiling, so nearly no overheating is possible if care is taken about residual water content. Let the steam low to a next container and there cooled in some cool water so condensed water is filling this second vacuum container.
Beer barrels may be used (SS and Al) but the fluid film evaporator may require a higher internal accuracy and smoothness if operated with wiped film. Or may require some lengthwise scratching to enhance capillary wetting.
Pasteurizing: high pressure 5 to 20 Kbar is best (but said to be expensive).
Have success!
RHABE
Good Answers: 27
04/17/2009 11:48 AM
Hi Rhabe........currently I'm using gravity as my RO pressure but haven't bothered to measure it. It is only to filter out about 70% of the water. The trick would be to find a membrane that can filter out water to exact proportion. Unfortunately my bank manager has convenient heart attacks everytime he sees me.
I like the idea of a double vacuum chamber. I'm currently using a double boiler to finish off the syrup (impossible to burn) but needs constant attention. Someone (sorry, forgot who exactly) mentioned using oil in the first boiler (I've been using water) and I suspect this is also an excellent idea.
Good Answers: 120
04/17/2009 12:02 PM
RE: Someone (sorry, forgot who exactly) mentioned using oil in the first boiler (I've been using water) and I suspect this is also an excellent idea.
The problem with water in the first boiler is the difficulty of getting it above 100C, where it boils.
there are a few ways,
pressurization = risk of bang.
hot oil = risk of burning sysrup with bad control
hot salt water = less risk of burn, as long as you keep the salt out of the syrup.
since salt does not evaporate you can mark a level and replace water boiled off and as long as you keep the salt out of the syrup you are OK. You can also use glycerol to elevate the boiling point a few degrees.
Per Ardua Ad Astra
Good Answers: 27
04/17/2009 4:40 PM
I'm the last to reply to your suggestion because so far it makes a whole lot of sense and I can't shoot any holes through it. I never thought about using oil, glycerol or salt water but come to think of it it's a darn good idea!
How come I never thought of that!
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
04/17/2009 9:31 AM
I don't know much about raw syrup, but where I live, there are a lot of farms. When I first tried unpasteurized milk, I found it delicious. It had that 'Oomph' factor that the milk you find in the store didn't have. I find that I would feel the same way about raw sap. Seeing as it has so many nutrients before it is boiled down, I would definitely give it a taste.
If no one wants you to distribute maple syrup screaming 'sterility' concerns in your face, at least you can take comfort in knowing that you have something that no one else has!
I don't know much about maple syrup and the pasteurization process, but can't you just boil it just enough for the concoction to be considered free of bacteria and then can/bottle it?
Good Answers: 27
04/17/2009 9:43 AM
Thanks Jaxi......you have the right idea. I also have tasted this unpasteurized milk and the cheese made from it. It is incomparable....and some say doable on a large scale considering all the sterility factors now involved in milking.
Unfortunately the same rules apply to milking trees.
Good Answers: 27
04/17/2009 9:38 AM
Thanks everybody for the fine advice.
I'm in a position where the food agency allows me two temperature extremes........the first is 100'C + ...or boiling point, and the second is a max. 4'C chill point which facilitates a specific amount of allotable time for bacteria not to propagate. Unfortunately, warming is not an option.
I was thinking somewhere along the lines of using a type of tuning fork that vibrates at a high frequency that some cold water misting machines incorporate. I like the idea of using vacuum and am condsidering building a small model of a double flask....similar to a double boiler but in reverse.
Good Answers: 120
04/17/2009 9:44 AM
http://www.google.ca/search?hl=en&q=%22reverse+osmosis%22+%2Bsap&btnG=Google+Search&meta=&aq=f&oq=
Per Ardua Ad Astra
Good Answers: 27
04/17/2009 9:56 AM
Thanks ...I use reverse osmosis and bacterial filters.
I cracked off the excess water after ro'ing by flash freezing using co2. The sugars separated from the water and the resulting taste and colour was quite good.
The colour is highly dependant on the run stage....ie..the first sap to run has the least amount of aldehydes and tannins and is a light amber colour. The colour becomes darker as sap run time goes on. There are two stages to boiling off....one is a preliminary stage where most of the water is boiled away and a second finishing stage where the final amount of water is slowly evaporated. Of course there are filtration stages inbetween for all except the final one.
Good Answers: 101
04/17/2009 10:54 AM
In that case what you'll need are ultrasonic transducers . They have the advantage of killing bacteria by rupturing them open while simultaneously vaporizing the excess water . Before you use them though, it'll be best if you check with the transducer manufacturer if thickening maple syrup is a recommended use for them .
Good Answers: 27
04/17/2009 11:37 AM
That's the track I'm aiming at. Didn't know but suspected if frequency high enough then bacteria will be killed off. Irradiation another prospect ... presently using 10,000W of UV light.
Good Answers: 109
04/17/2009 12:59 PM
Hi Duckinthepobd,
UV is good but is penetrating into water only a few millimeter.
So let the stuff stream slowly (how long does the UV radiation take to kill the worst species?). Down-streaming a slightly inclined tray with a fluid thickness adjusted by the feeder and viscosity and inclination. This will do the best possible.
But:UV is generating ozone in the water and this will oxidise very fast everything that has some carbon or hydrogen atoms: the taste will be affected.
RHABE
Good Answers: 27
04/17/2009 4:30 PM
Yes....that's exactly how it's done with a shallow tray in a sealed environment after filtration. So far we haven't detected any bacteria so this is just for added safety. I have given samples to test for mould and virus' and the amounts are too small to worry about.
To explain...all the trees are strung with poly tubing which is under vacuum to a central collecting point. In a perfect world no wind will blow and no branches will fall on the tubing. When this eventually does happen the largest concern becomes contamination. As long as the weather is cool I don't worry too much. If the temperature rises above 4'C I begin to worry. I also get very upset when some bear discovers a fountain of delicious and sweet nectar flowing from a hose he has learned to disconnect. I have also discovered it is impossible to fight with this creature so I hang some buckets for him and the deer to drink from....so far so good.
Good Answers: 27
04/17/2009 7:21 PM
Guess what? News flash........ some guy just got busted in Toronto for purchasing ultrasonic transducers for shipment to Iran ostensibly for plutonium enrichment process.
I was about to make inquiries but think I'll wait a bit before being accused of attempting to make my maple syrup collapse into a critical mass state.
Good Answers: 42
04/17/2009 10:56 AM
I grew up in Mennonite country.
Spigots in the trees, pails of sap, boiled in open pans over a wood fire.
Absolutely delicious!
We freeze the 4L bottles of syrup and they last for years.
Good Answers: 27
04/17/2009 11:30 AM
Yep......that's how we did it also for many years. Knee deep in snow. Deer would drinking out of the buckets. 200 trees tapped. Open fire. It was a lot of fun.
Today it's 15k trees all vacuum hosed together, RO filtration, stainless steel vats...still use heavy horses though.
04/17/2009 11:16 AM
Maple syrup is generally collected when the nights are below freezing and the days above freezing. The American Indians would leave containers of sap out in the cold overnight. The low sugar content water will freeze and gradually the remaining syrup thickens. Try freeze concentration.
By the way this is also a method that can be used to make "apple jack" from "turned" apple cider. Put the cider in a barrel and rotate the barrel regularly during cold winter nights. The liquid remaining in the center of the ice will have a high concentration of alcohol.
Good Answers: 27
04/17/2009 11:31 AM
You're my kinda hillbilly! Apple Jack eh!
04/17/2009 3:20 PM
I wish I had some Maple trees. I pay 20 bucks a quart for Maple syrup. Sometimes wish I'd never tried it, I can't go back to the cheap stuff now.
Good Answers: 27
04/17/2009 4:14 PM
Considering some of the cost factors involved it's actually gone down in price compared to twenty years ago...value of the $ yada yada...........
I'm part of an 8 member co-op so we try and keep our prices reasonable.....$50C Imp. gallon for #1 grade. All surplus goes towards upgrading and maintenance of the equipment. Though much of the clientelle are restaurants unfortunately we have no control over the pricing after it's been purchased by re-sellers.
Good Answers: 146
04/17/2009 9:09 PM
This thread is a great read, way more options in processing than I ever dreamed of... but there's more...
Check out this article by Favreau et al from McGill University, on microwave processing of maple sap to syrup. Can do it.
Also, for those who recommended filtration, Pouliot et al from Laval have used ultrafiltration to produce a clear "cold sterilized" sap. If you want to dispute the temperature restrictions with the CFIA, a copy of this research might be useful.
I went looking, and found surprisingly little literature on medicinal constituents unique to maple syrup, but the Japanese and Chinese are starting to publish research on Maple leaf and bark constituents: some of their Maple species are used in traditional medicine and are reported to have anti-cancer effects.
"Quebrachitol", of the inositols, is mentioned in a 1967 study by Stinson et al, where it's said to be more abundant in maple sap than all monosaccharides combined. Maybe an important nutrient for neural messaging systems, it looks as though there's research ongoing, so we may see some news on this in the near future. Eyemark inositol.
Not that you will ever need medicinal markets to sell maple syrup!! But I take perverse enjoyment from the thought that lavish treats are.. good for me
incus opella
Good Answers: 27
04/17/2009 9:34 PM
wow....just added all to bookmarks. Ultrafiltration good but membranes are cost prohibitive.
Had heard of research from U of Guelph regarding calcium type found in sap. Apparently high in strontium and anion binders. Possibly good for osteo patients?
Good Answers: 146
04/17/2009 9:58 PM
Good call. Korean traditional medicine calls it "bone-benefit-water", and research found it ameliorates low bone density in a mouse model.
incus opella
Good Answers: 101
04/19/2009 11:58 PM
UF isn't really suitable for highly concentrated maple syrup anyway . The viscosity is too high . To know more about ultrasonic transducers and their suitability for this purpose, you can contact Mr. Scott Morgan at smorgan@humidifirst.com . His company manufactures transducers for vaporizing water, so he can advice you on this .
04/19/2009 12:06 PM
Perhaps some of people don't know the amount of energy it takes to make M.S. To put it into perspective the concentration ratio is 40:1. Therefore it takes 40 litres of Sap to make 1 litre of Syrup. Now you can understand why many large scale producers go to R.O. This was a good year for syrup as around here they were averaging 1.25~1.5 litres per tree.
Regarding the Sap, it has the consistency and clarity of water, as well the taste is similar to water just with a very slight sweetness although hardly noticeable.
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
Good Answers: 27
04/20/2009 7:27 AM
Hi PTT.......this has been the best year for syrup since 25 yrs. We were averaging 38/1 ratio as opposed to the norm 40/1....and yep, you're absolutely right about energy (mine and everybody else' who are scheduled for intensive chiropractic services) not to mention the boil off.
04/19/2009 7:33 PM
Been away on holidays, so didn't see this thread.
Reminds me of one of the challenges some months back to get water out of an alcohol mixture.
If you are to filter the sap before final boil down (and flavour concentration) then what about adding "plaster of paris" to bond with some of the water molecules?
This is easily filtered off, and can be readily recycled by heating again to drive off the water content.
(The idea actually came from someone else, but I was so impressed that it's stuck in my memory.)
Good Answers: 27
04/20/2009 10:00 AM
OK.......this is so far out in left field that I'm now tempted to try it. If there are no residual noxious chemicals, flavours or ph disturbances the idea must pass the food inspection authorities. Do you know of any research or documentation that proposes this?
Good Answers: 120
04/20/2009 10:43 AM
The formation of hydrates is a well known procedure to remove water from otherwise hard to separate mixtures, drying ethanol, for example, is one of the common ones in use.
It is very likely there will be a strange taste and the matrix of hydrated plaster will entrain a large amount of the syrup as well as water since you are concentrating 40:1 you will need so much plaster to deal with 40 pounds of syrup that the one pound of syrup left will just make a poor glue as the end result.
With Ethanol, you distill to the aeziotrope of ~95% and then use an anhydride to strip the lst 5%. The amount left on the hydrate crystals is small in comparison.
Per Ardua Ad Astra
Good Answers: 101
04/20/2009 10:47 AM
Plaster of Paris is non-toxic. In fact, it's used as a coagulant in tofu production.
Good Answers: 120
04/20/2009 10:57 AM
Yes, Gypsum, I see it in the recipes.
A small amount is used, it seems to be flavor free
http://www.soymilkquick.com/makingtofu.php
http://en.wikipedia.org/wiki/Tofu
I think there is too much water in maple syrup for it to work.
Per Ardua Ad Astra
Good Answers: 101
04/20/2009 12:21 PM
It might work if it's concentrated enough.
Good Answers: 120
04/20/2009 1:05 PM
These anhydrides can only be used for removing small amounts of water. Syrup is 60-70% water, so it is totally impractical to use it at any stage, like going from 20% to 30% would take on a 1000 pound batch(10 pounds of pure sugar) of say that you boil from 1% to 20% = 50 pounds of 20% sap you need to take to 30% or 33.3 pounds of syrup with enough plaster to absorb 16.7 pounds of water?
I think you would have a sweet lump of sticky plaster
Per Ardua Ad Astra
04/20/2009 11:59 AM
Yep! And they thought adding Melamine to baby formula would be fine too!
I would consider addition of any foreign material in process to the actual product to be "science experiments" only. Introduction of R.O. was a great idea and IMO the best and perhaps the only way to improve in the production of M.S. in comparison to the traditional method of full evaporation from start to finish. BTW we had pancakes last night with Syrup made on our farm the traditional way (we yielded 110 litres from 75 taps on 45 trees) and it was grrreeaatt!
Good Answers: 27
04/20/2009 12:24 PM
Nice!!
My favourite has always been the second run. It's darker but has (in my opinion) the most flavour.
The co-op we're composed of uses approx. 50 face cords of hardwood to boil off the remaining water AFTER filtration. Of course the idiot who built the boiler (me) is the only one capable of running the damn thing which is why, after ten years, I'm looking for an alternate means of syrup recovery...though if retrospect is 20/20 I'm probably going to get stuck with running the damn thing after building it.
04/20/2009 5:27 PM
Seems the idea has hit the "thought" button for a few readers.
I had imagined using only enough to absorb the first 10% of water rather than all of it. This would mean less water to boil off from the remaining syrup.
The energy needs would not change though as to "re-constitute" the plaster for re-use still requires heat.
I imagine though the set-up should be using very shallow pans over the heat, a little like jam making so that evaporation is enhanced. High draft over the pans would help drive away the water vapour and provide a lower partial pressure for subsequent evaporation.
Good Answers: 120
04/20/2009 5:29 PM
Give Maxwell's demon a pair of molecular tongs and put him to work.
let him have 1% of the water as his fee...
Per Ardua Ad Astra
06/19/2009 10:00 PM
hello duckinthepond,
i was going to make the same suggestion as post number 17, but he beat me to it.
i do have something else that might help your process though. i found out that bacteria can not survive high magnetism. i found this out researching diesel fuel. there is a product out there, i believe it is called "debug". it is a cylinder that has opposed magnetic disks inside. you pump the diesel thru it and it kills the bacteria. these are not electro-magnets, just magnets. the cylinder is designed to go inline. it has threads at each end. wasn't that expensive either. you just pump the fluid thru it. you could put one on the output line wherever you are pumping.
joe
Register to Reply 53 comments
Anonymous Poster (1); artbyjoe (1); artsmith (3); aurizon (9); dayhead (1); Duckinthepond (20); DVader1000 (6); GW (1); Jaxy (1); Just an Engineer (2); Part time thinker (2); PWSlack (1); Qqberci (1); RHABE (2); Yosemit3 (1); zasmine (1)
You might be interested in: Plywood, Penetrants and Penetrating Oils
