Previous in Forum: Lead Calcium Plates Dumped into Sodium Bicarbonate Solution   Next in Forum: GUillotine Cutter Used in Chewing Gum Plant for Cutting of Pillow Gum
9 comments
Heating
04/21/2009 8:56 AM
I want to generate an out put of 36kW of heat from a hollow steel tube 0.75" D, 2' long in the same amount of time. Max. temp cannot exceed 200F. What is the difference in dwell time, and power consumption between:
1) Convective heating of tube via heat tape
2) Resistive heat of tube via direct current flow/application
3)Inductive heat via a coild placed aroung tube
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Heating
04/21/2009 9:04 AM
You'd need a spool of heat tape a mile long to get 36kW, Guv. I haven't got enough for yer at the moment. The problem is keeping the damn thing below 200F. What in Aveley's name are you doing, fer Pete's sake? <Cough, splutter>
Essex jobs for Essex yobs! <Burp>.
Re: Heating
04/21/2009 9:39 AM
If i was supposed to care about price, I'd go for resistive heating with thermostat. And allow the tube heat conduction do the rest. If I'm not worried about cost, go for an inductive system with different circuits and sensors, controlled by PID. Inductive heating is somewhat easy to control because you can adjust the electric source parameters easily. Oh, ok, I said its easy, not cheap.
Humm... suspicious you are...
Good Answers: 103
Re: Heating
04/21/2009 9:47 AM
Just a bit tough ?
3/4" tube, 2' long, guzzling 36KW and then where does it throw it out ? to maintain the temperature to 200oF max ? I will love to have this for my heat exchangers where even 10-12KW requires 3/8" copper fully finned tubes and a lot of them.
Or it is just to heat it to this temperature and then reduce the power to maintain the temperature ?
I will go usually with the Inductive, but the cost may be a bit high as bhr said. But maintaining the temperature may have too fast switching anyway.
Re: Heating
04/21/2009 9:58 AM
Yeah. You tell 'im. <Splutter>
Good Answers: 101
Re: Heating
04/21/2009 12:03 PM
He's probably following your signature about making the illogical logical , and now he's trying to do it for real .
Good Answers: 103
Re: Heating
04/21/2009 11:18 PM
I doubt it. he looks sincere and dynamic. He must have mistyped, it might be 36mW or 36W
Re: Heating
04/21/2009 9:57 AM
That's about the same size as an immersion heater element, Guv, and they're rated at only 3kW. You want 36kW and to keep its temperature below 200F? Strewth! you aren't half going to need some turbulence past it! <Cough, splutter>
Re: Heating
04/21/2009 11:21 AM
A back-of-the-envelope calculation would indicate that it is not possible to transfer this amount of heat without increasing the surface area of the tube many times, as sb has already correctly pointed out.
Further, the nature of the fluid in contact with the pipe is not stated. Fluid properties will have a substantial impact on the heat transfer operation.
Good Answers: 109
Re: Heating
04/22/2009 4:38 AM
More likely above 2000°F at this power.
Direct heating preferred.
RHABE
Register to Reply 9 comments
bhrescobar (1); DVader1000 (1); PWSlack (1); RHABE (1); sb (2); Stinky Pete (3)
