Previous in Forum: Skirt & Leg Mounted tank?   Next in Forum: gland steam temp high!!!
9 comments
SO2 emission from diesel engine
04/21/2009 3:49 PM
Hello All.
Is it safe to assume that all sulfur in diesel fuel is emitted out exhaust as SO2 ?
Or is some emitted as other sulfur oxides?
I am just trying to find out the mass of SO2 in the exhaust if I know the percentage of sulfur in the fuel that is used...
Thanks.
Good Answers: 62
Re: SO2 emission from diesel engine
04/21/2009 4:16 PM
Depending on your geography and the fuel type used the sulfur content can vary greatly going IN the tank.
Just wanted to say....
04/21/2009 6:32 PM
Lub oil contamination, there is plenty of information if you google it.
Regards JD.
04/21/2009 10:04 PM
Hi Greg,
Knowing some chemistry, I would think that there could also be a significant amount of SO3 generated. I don't know combustion chemistry at all so I could be wrong. I would do a search along the lines: +diesel +combustion +"sulfur dioxide"
Mike
04/22/2009 3:08 AM
<...Or is some emitted as other sulfur oxides?...>
Well, apart from SO2 and SO3 there aren't many others!
Good Answers: 247
04/22/2009 9:53 AM
Diesels produce H2O as a product of combustion, and run with excess O2 under anything but full load, so:
(2)SO2 + O2 + (2)H20 >> (2)H2S04
See also.
04/22/2009 12:58 PM
This spreadsheet is based on EPA's AP-42 emission factors and is used for Indiana air permits. To calculate, you take hp times 8760 hrs to get hp-hr/yr. Then, multiple hp-hr/yr times emission factor for SO2 (weight % sulfur times 0.00809) and divide by 2000. This will get you your tons per year of SO2 emissions.
Appendix A: Emission Calculations
Page 1 of ? TSD App A
Internal Combustion Engines - Diesel Fuel
Turbine (>600 HP)
Company Name:
Address City IN Zip:
Permit Number:
Plt ID:
Reviewer:
Date:
A. Emissions calculated based on heat input capacity (MMBtu/hr)
Heat Input CapacityS== WEIGHT % SULFUR
MM Btu/hr
0.0
Pollutant
PM*PM10*SO2NOxVOCCO
Emission Factor in lb/MMBtu0.10.05730.00.10.85
(1.01S)
**see below
Potential Emission in tons/yr0.00.00.00.00.00.0
**NOx emissions: uncontrolled = 3.2 lb/MMBtu, controlled with ignition timing retard = 1.9 lb/MMBtu
B. Emissions calculated based on output rating (hp)
Heat Input CapacityPotential ThroughputS=0= WEIGHT % SULFUR
Horsepower (hp)hp-hr/yr
0.00.0
Pollutant
PM*PM10*SO2NOxVOCCO
Emission Factor in lb/hp-hr0.00070.00000.000710.00550
not provided
(.00809S)
**see below
**NOx emission factor: uncontrolled = 0.024 lb/hp-hr, controlled by ignition timing retard = 0.013 lb/hp-hr
Note that the PM10 emission factor in lb/hp-hr is not provided in the Supplement B update of AP-42.
An average conversion factor of 1hp-hr = 7,000Btu is provided below.
Methodology
Potential Througput (hp-hr/yr) = hp * 8760 hr/yr
Emission Factors are from AP 42 (Supplement B 10/96)Table 3.4-1 and Table 3.4-2
1 hp-hr = 7000 Btu, AP42 (Supplement B 10/96), Table 3.3-1, Footnote a.
Emission (tons/yr) = [Heat input rate (MMBtu/hr) x Emission Factor (lb/MMBtu)] * 8760 hr/yr / (2,000 lb/ton )
Emission (tons/yr) = [Potential Throughput (hp-hr/yr) x Emission Factor (lb/hp-hr)] / (2,000 lb/ton )
*No information was given regarding which method was used to determine the PM emission factor or whether condensable PM is included. The PM10 emission factor is filterable and condensable PM10 combined.icdsl600.xls 9/95
Note to Reviewer: Check the applicable rules and test methods for PM and PM10 when using the above emission factors to confirm that the correct factor is used (i.e., condensable included/not included).updated 4/99
"We cannot sow thistles and reap clover. Nature simply does not run things that way. She goes by cause and effect." Napoleon Hill
04/22/2009 12:59 PM
That spreadsheet didn't exactly line up the way that it should. I can email it to you if it would help you.
08/03/2010 9:25 PM
AP-42 emission factors back in 1996 didn't account for ultra low sulfur in today's diesel. I believe it went from 5,000 ppm back in the 90's to 15 ppm today.
04/06/2010 7:50 AM
I would appreciate receiving the spreadsheet to the following email
moshrik@yahoo.com
Register to Reply 9 comments
Anonymous Poster (2); Blink (1); edignan (1); jdretired (1); Mikerho (1); PWSlack (1); WWkayaker (2)
