Previous in Forum: Relevance of Microsoft Certificate   Next in Forum: A YouTube question
CLEAN RUST IN PLATES
04/25/2009 1:53 PM
HOW WE CAN CLEAN RUST IN PLATES WITH SQUARE AND BEVEL EDGES FOR WELDING IN ONE MODIFIED SERIES ARC PROCESS
Re: CLEAN RUST IN PLATES
04/27/2009 3:30 AM
  1. Turn off Caps Lock
  2. If polishing with abrasives is unattractive, consider chemical rust removal options.
04/27/2009 2:16 PM
do you have information what kind of abrasives or tool is recommend for reduce the time in manual operation, the chemical rust removal maybe is difficult because in the area have many people working and the equipment is near to the area of cleaning.
Good Answers: 97
04/27/2009 4:28 AM
belt sander
04/27/2009 2:18 PM
the size of the plates is maximum 40 ft lenght, maybe the belt sander is good option. do you have information about this equipment?
Good Answers: 97
04/27/2009 2:22 PM
Where are you?
What is your need?
Do you need to remove rust from the area to be weld prep'd or entire plate?
04/27/2009 3:50 PM
ONLY NEED REMOVE RUST FROM THE AREA TO BE WELD PLATE WITH PLATE AND TO WELD STIFFENERS ALONG THE PLATE.
IAM FROM VERACRUZ, MEXICO
Good Answers: 97
04/27/2009 6:25 PM
From these links you will read about their use on sanding wood/metal but you put on metal sanding melts and go:
http://www.taunton.com/finehomebuilding/how-to/articles/survey-belt-sanders.aspx
Anonymous Poster (3); bwire (3); PWSlack (1)
